Question about Garden
OPened my pool up about a week ago, got out almost all of the leaves, put in 2 bags of "shock it" each day for 2 days. My pool is blue but very cloudy. What should be the next step to get rid of the cloudines, and also is it safe to swim in this condition?
  • Jason r. Hicks May 31, 2010
    Thank you very much for this useful information. I hope i can ask a few more questions for more information.Once again thank you for the help.
    Now if I'm understanding you correct I should put four gallons of the muriatic acid in first then 2 gallons per week of ACID?
  • 10,319 Answers
Add muratic acid to the water and use a testing kit to check the PH before using it. This will eliminate the cloudiness in the water
Posted on May 31, 2010
  • 1 more comment
    28000 gallon pool how much of the muriatic acid should i put in?
  • frank thomas wilson
    frank thomas wilson May 31, 2010
    28,000 gallons of water is the same size I had
    Use 4 gallons on the initial shock treatment when you first open the pool up. The 2 gallons per week there after. If the pool is use quite frequently and gets cloudy sooner use one gallon after heavy use of your pool from a lot of people in it
    Yes that is the way to do it
After harsh winter,green pool,levels of everything are fine except salt which we are adding. Have Penair filter, so what is optimum speed &for how long to get my water crystal clear and blue
It has been 15 years since I owned a pool. My best way was to shock pool with a liquid shock , run filter for a day then broadcast aluminum sulfate with filter off. Usually in a day or two all debris is on bottom of pool. This debris must be vacuumed to waste because it will clog the filter.
Apr 04, 2018 | Pool & Spa
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
I have a 15foot round pool that is 48 inches deep. My pool is still cloudy after putting clarifier in it. Plus it get shock in it weekly. I also boost it weekly. The salt machine reads normal However...
first balance the pH and then test other chemicals BALANCE pH FIRST. and rum pump continuously for a few days. and then about 8 hrs a day.
Jay the pool pump repair guy in longwood Florida.
Feb 28, 2018 | Intex Automatic Salt Water System for ...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
My pool water turned green after I put an alkalinity and ph stabilizer in it what can i do to get it clean again?
Pure bleach, gets mine clear when it turns green. If its just clear water with a green tent then i would use bleach. I only use bleach to maintain my pool. I have a 20 round 88,00 gallon pool and i use 1 and half gallons of bleach every week to keep my pool clean and i use a bag of shock it every month or so, all the shock is used for is to drop everything to the bottom so i can vacuum it. If u have a smaller pool then i would use about 3/4 a gallon a week on a 15 round 5,000 gallon pool and about a half a gallon for a smaller pool. But it will for sure get ur water clear and if u dont want to use bleach then shock it will do it and to maintain use the shock it atleast once a week. When u use the bleach make sure u pour in over the where the water returns in your pool slowly to help it not hit the bottom. When u pour it over the clean water that is returning to your pool then it will help spread it throughout your pool and dilute it so it wont spot your liner up with lil bleach spots. So just pour it slowly over the return water comin out of the side of your pool. Also if its an algea problem then bleach will def work to prevent and kill the algea and u can u an algeacide to get rid of it if u dont want to use the bleach. The bleach is the cheapest way and fast way i have found to keep a pool clean. My pool is cyrstal clear, u can see any specs that is floating in it I hope this helps, please let me know what u think and rate solution. thanks and good luck
God bless
Jun 15, 2010 | Intex Easy Set Pool 15x36
LG Dare dropped in Pool
Just put it in a bag of rice for couple of weeks. The rice pulls all the water or wetness out of the phone. How do I know, Well I found a brand New Lg Dare phone in a puddle, put it in rice for 2 1/2 months. I took it out of the bag, put it together, turn it on. To my amazement it worked. Ran to store, bought a charger, and it has worked every day since.
Jun 18, 2009 | LG Dare VX9700 Cell Phone
Creative labs zen v 4gb mp3 player seems to have haywire...
It probably has some moisture still in it and needs to dry out.....This happened to me with my iPod....Put in a window seal that gets sun light all day and leave it there for 2 days....A friend of mine dropped his in a craper and he put his in a ziplock bag full of kitty litter and it worked as well.....So I would give either one of those a try...what’s the worst that can happen...it dries out and works :)
Good Luck and let me know if this helped
cbinny1
Jul 23, 2008 | Creative Labs Zen V MP3 Player
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
