Question about Akai LCT3201AD 32 in. LCD Television
Blinking on/off button but no picture when trying to turn tv on.
  • 597 Answers
Power board
Posted on May 31, 2010
Picture went out and red light on the stand by button blinks ten times and stops for sec and starts the ten blinks all over. When I turn TV on I can hear sound of the tv trying to turn on but no sound or...
10 blinks on KDP-57WS655 model no. is an error code for "High voltage protection". I can tell you exactly which part gone bad and assist you to fix it yourself. Click it here.
Jdvillanueva
Sep 29, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
No picture, no sound
we need a request on what the blinking red light means on your model number and manufacturer of TV, we can then try to see what the blinking light means,(although it doesn't sound good) You ca always unplug the DVR and see if there is a change, then you would know it was the DVR
Thanks for the rating
Apr 12, 2009 | Televison & Video
SONY KV32-FQ70U BLINK ERROR
Try unplugging the TV for about 10 minutes and then tunung it on again. Try a factory
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
I'm assuming step 2 means hold down the power button.
Nov 27, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Mitsubishi WS-65511 Turning off
Good Day;
Your chassis V21, 2002 model TV has a problem, but to determine what, try this; press the 'input' and 'menu' buttons on the TV"s front panel for at least 10 seconds. Count the blinks (after releasing); eg blink, blink pause 6 blinks = code 26. The code will repeat 3 x's. The most common problem is the convergence IC's are bad or fluid on the boards.
Good Luck, Day let me know, Big Irish.
Jun 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Akai LCT3201AD 32 in. LCD Television Logo
65 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
