Question about Maytag MTW5600TQ Top Load Washer
2 problems hot comes on when cold selected does not complete wash cycle must use dail to finish
  • 333 Answers
Sounds like the selenoid valves are backwards. Or the water hooked up backwards. Or actually like the cold water one isnt working at all. Either the selenoid or the screen stopped up. Even on cold water i noticed that some washers use warm. But all of them uses cold water to rinse. At least the last rinse. So when it uses cold water there isnt any. First of all, Switch the two wires with each other and wash on hot and see if cold works then. If not Take the selenoid out and apart then clean the diaphram real good with soap and water then pup back together.
Posted on Jun 02, 2010
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
I have set the rinse cycle set to cold on our washing machine, however the clothes are rinsed hot, when I take the clothes out of the washing machine after the cycle is complete they are hot. How do I...
the hoses may be reversed...select cold rinse and turn on washer...if its hot..then try cold wash, is it hot? then try hot wash...is it cold? if so, check your hoses are on correctly....reverse hose's
Jan 23, 2011 | Kenmore Washing Machines
Cothes are being put on a 40 wash but coming out stone cold is there a way to check if water is heating as no fault is flashing up on display
I would expect the clothes to be cold after the cycle is finished, as it will have completed at least 3 cold water rinses, so I do not think you have a problem.
If you want to check if the heater is working o/k, then select a hot wash programme, say 90 degrees, and feel the door glass after 30 mins or so, it should feel warm , and if the heater is not working, then normally the washer will not complete the programme.
Dec 01, 2010 | Washing Machines
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Maytag MAV6200 will not washer on cold water cycle. Could this be a problem with the push button switch? Washes on all other cycles. However, the warm water is very hot, not warm.
Your cold water inlet valve has more than likely fialed.or.... the inlet screen is completely clogged. First turn off the water to your unit both hot and cold water lines. Then select the wash cycle w
ith hot water only and listen for a hum from the inlet water valve. Then select cold and see if you hear a similar hum. If you do not hear a likewise hum then the cold water solenoid on the water valve has failed and will need to be replaced. (Sometimes this requires the entire water valve be replaced due to the design of the assy) If you hear a similar hum then remove the hoses from the water valve and check for a clogged inlet screen just inside the water hose attachment fitting. If you can not tell if it is clogged remove the screen and hold it up to the light. You should be able to see light through the screen. If it is clogged scrub and wash the screen under running water. It is prety easy to tell if you have it clean. Once you finish reinstall the screen in the water inlet valve, reconnect the hoses and turn on the water. Good luck.
Jan 07, 2010 | Maytag MAV6200 Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Hot water rinse when cold rinse is selected
First off make sure your hoses in the rear are on correctly there is Stamp on the back of the unit H=hot C= Cold if that is ok we will need to look deeper let me know
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MTW5600TQ Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
