Question about GE Spacemaker JVM1640SJ Microwave Oven
Just after heating a hotdog in the microwave (spacesaver) the thing went black - no clock, no lights, no nothing. Is there a reset button on this unit?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ewrqty
Posted on Sep 30, 2010
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacesaver microwave is not working...no power at all.
Usually a Thermal protection (Like Circuit Breaker) this should be tested with Multi Tester. If this open, no Electrical Power goes to the Primary Winding of your High Voltage Transformer and will not power up your magnetron therefore no heat inside the Microwave Oven.
Jul 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave oven does not have power to the panel.
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Jul 02, 2009 | GE Spacemaker JVM1750 Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is on when you shut the door
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
The display lights are all solid and nothing happens when you press on the keys. I have a GE Sensor Microwave. I bought it in September of this year. Came home from work one day, went to heat something up...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may have a failed keypad.
Dec 11, 2008 | Microwave Ovens
G.E. Spacesaver Microwave - Keypad Won't Work
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You may have a problem with the keypad or the control unit (circuit board / smart board).
We repair these on a regular basis. Details and *critical* safety, disassembly, and troubleshooting info is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Nov 20, 2007 | Microwave Ovens
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
69 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
