Question about Garden
How do we change the blade belt of a Mountfield 1538H-SD
    Brigadier General:
  • 3,917 Answers
Please find the step by step procedure to change the drive belt of the Mountfield.
http://www.fixed4free.com/answers.php?id=130522
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
2 Suggested Answers
  • 407 Answers
SOURCE: I have a mountfield 1538h-sd blades disengaged
The belts may be loose.With the mower off,engage the blades and check the tension.Next would be to get under the mower and check for debris in and around the lever that engages the blades.Sometimes trash will get hung up in there and the blades will disengage.The next step would be to inspect the pulleys for debris and to make sure the spindles are not bent.While at the pulleys make sure there are no burrs or cacks in the pulleys,as that will cause the blades to disengage.
Posted on Jun 03, 2011
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Why wont my mountfield 725m mower go into blade motion
I would check the mower deck itself. This usually happens when it clogs with grass or something got jammed in the belt or pulleys.
Aug 30, 2014 | Garden
Instructions replacing mountfield drive belt
When replacing the drive belt on a rear-drive lawn mower, make sure the spark plug is disconnected, remove the blade, take off any bolts for the belt cover and remove the belt. Find out how to put a drive belt on the engine pulley with help from the owner of a small engine repair shop in the video on the website given below http://www.youtube.com/watch?v=3G0a11VtRRc
Aug 17, 2014 | Garden
FIX BELT DIAGRAM MOUNTFIELD 1538H
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 19, 2012 | Cars & Trucks
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
I have a mountfield 1538h-sd blades disengaged while mowing belts seem very slack ,but the belts are all on the pulleys.
Jun 03, 2011 | Garden
I HAVE AN OLD RIDE ON LAWN MOWER LABLED AS MOUNTFIELD 7 WITH A 25 LABLE ON THE FRONT I BELIEVE ITS APPROX 1978 AND I NEED A DRIVE V BELT FOR THE BLADE OR A PART NUMBER
if you have the old belt take it with you to a local parts store. if you don't have the old one, then take a long piece of cord and run it around the pully's the way it should go and tie it to the right size ( or atleast close it it) and take that to the parts stor and get a belt that size you can adjust the tension when you get it back on...good luck
Apr 01, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
1,358 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
