Question about Alpine MRP-T220 Car Audio Amplifier
Ive set this amp up in my van with alpine spr 17s component speakers and on the first attempt they worked perfectly but after about 5 minutes on volume 12 or more it would cut out and come back in every 1 or 2 seconds for less than half a second. when trying to work out what it was i changed the balance all the way to the left and it was fine! so i tried it all the way to the right and the same thing would occur. am i right to assume that this problem is more than likely going to be caused by faulty wiring? thanks!
    Scholar:
  • 84 Answers
A short could be an issue for sure. But I don't think that's what you have here I believe it's improper wiring to your amp from your speakers.
Posted on May 31, 2010
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
I have a alpine CDE 152 head unit in my car and just put in alpine SPR 60 coaxial speakers in the rear. thought the head unit would be enough and want more punch from the base.. do i need an amp or i
get the alpine ktp445 mini amp ,it should be compatible (check your manual for your HU it will say ) its a plug and play install and you will hear a great improvement as I did and still got mine with the alpine cda 117 .
Apr 04, 2014 | Alpine Car Audio & Video
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Jan 27, 2010 | Car Audio & Video
Im getting a buzz from the tweeters only front and rear.only when car is on no matter if radio is on or not.the buzz stops if i turn on my headlights. i have it hooked to a pdx5 alpine amp.
Yeah problem solve it was tricky. All I did to resolve the problem was ah ah not so fast if you want the answer it'll cost you only 9.95 one time fee. So feel free to e-mail so I can tell where to send the check. This reply is for fixya.
Oct 01, 2009 | Alpine SPR-17S Car Speaker
Speakers quit
check ur wires and make sure ur ground is good.be sure u have the neg. and pos. rite all threw the car
Jun 18, 2009 | Alpine Type-R SPR-69LP Coaxial Car Speaker
Alpine MRP-T220 Car Audio Amplifier Logo
59 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
