Question about GE Spacemaker JVM1540 Microwave Oven
My jvm 1540 will not heat. any advice? - GE Spacemaker JVM1540 Microwave Oven
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
1540 no turn no heat
There is a fuse and it may be some other things.But if you don't feel good about doing this kind of repair, I would have it serviced.
Jun 18, 2014 | GE Spacemaker JVM1540 Microwave Oven
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
How do I access the fuse on a JVM 1540 Microwave?
On this model, the 20A ceramic fuse is located on the filter board near where the cord comes into the unit.
But if your unit is dead (
meaning no display, no light when you open the door and no beeps when you press a pad on the keypad) then it may be a blown fuse or a bad T.C.O. (thermal cutout / thermostat) on top of the oven cavity or on the magnetron.
It may also be the bottom TCO, not to be confused with the hood TCO, which should read normally open.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 26, 2009 | GE JVM1440 Microwave Oven
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker JVM 1533BD microwave runs but will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
stysty
Mar 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1443 - Unit makes a deeper noise and will not heat
Hello mrobinert,
The sound you may be hearing could be the filament transformer breaking down or the magnetron tube failing ..they will arc and eventually fail. If you aren't getting any microwave energy ( to heat material in the cooking compartment) then in all probability it is either the transformer, magnetron or high voltage capacitor.. None of which are something you want to repair yourself... My advice is that if the cost to repair exceeds teh cost to replace then just buy a replacement model. If yours is under 1 year old, then you may be able to negotiate and get a replacement from the store where you purchased it.. If it is older than a year, it's probably cost effective to just buy a new model.
Regards,
Rick
Nov 23, 2008 | GE Microwave Ovens
JVM convection microwave
I see. Okay, well then I would expect there's a problem with a high voltage part, such as the diode, magnetron or transformer.
Your model number should be entered as JVM192002 and you can find exploded views here.
You can usually find GE parts for much less here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Aug 05, 2008 | GE JVM1790 1000 Watts Convection /...
JVM1750SMSS CHARCOAL FILTER INSTALL
I just installed a JVM 1540 with the same grille. I removed the two top phillips screws before mounting the oven as I cannot access these screw heads once the oven is installed. It took me about 20 minutes of fiddling with the grille to figure out (no thanks to the manual) that the grille needs to slide to the left to release so you can change the light bulb/charcoal filter.
Nov 06, 2007 | GE JVM1750SMSS Microwave Oven
GE Spacemaker JVM1540 Microwave Oven Logo
223 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
