Brought my first amp -T1 audio LS 500.2. After installing have found the power goes off after about 30 secs, have triple checked wiring, it all seems fine. The remote connection to the head unit works fine as the LED indicator illuminates, the main power LED doesn't though. The fault LED isn't illuminated either so this indicates the amp isn't faulty. Have tested the sub on another amp and it works fine. I disconnect all the connections and left the amp for a couple of hours, reconnected it and the main power LED come on, music played for about 30 seconds and then it shut down again. Can anyone help please its driving me mad
SOURCE: Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Posted on Dec 05, 2007
tech48
  • 624 Answers
SOURCE: Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
SOURCE: denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
I have had this same problem. What is going on? Mine has blown twice, now out of waranty. What am I going to do?
I will never buy Denon again. ****!
Posted on Jul 22, 2008
LVT7857
  • 116 Answers
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
zenglish87
  • 5 Answers
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
What ingredients are in Hiram Walker's Triple Sec
Triple sec (meaning "Triple distilled") is a strong, sweet and colorless orange flavored liqueur. It is made (distilled) from the dried peel of oranges found on Curacao, an island in the Caribbean.
There are several brands including HW.
Jul 14, 2014 | Hiram Walker Liqueur Triple Sec 30 1.75L
I have a jx jl 500/l, amp will not power down unless underhood fuse is removed
check your fuse on the battery and check the fuse on the amp or it might b loose connection of power line and the remote wire(the blue wire
Aug 27, 2013 | Jl Audio 500/1 Car Audio Amplifier
There's a flashing green and red light when my car is on and the sub attached to the amp is making a heartbeat like noise when the light goes green and then the light goes red right away. everything is...
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Aug 19, 2011 | Jensen JXP680 Car Audio Amplifier
Amplifier shuts down after 30 secs of loud playing
Could be a couple of different things. It's more than likely the wiring between woofer and amp is the problem. Check the Ohm load on the woofer to make sure it's compatiable with the amp. If your woofer is wired at 1 Ohm, and the amp can only take a 2 Ohm load, it would cause this problem. Also, are you having any issues with the voltage of your car? If your car's current electrical system can't keep up with your higher power demands, then it might also casuse this problem. I would check the wires first.
May 27, 2010 | Solid Audio F15D 1-Channel Amplifier Car...
My sub has all bin wired up proberly the sub works for about 30 secs then the green light goes out and no power to the sub at all
Green light on amp?? Seems like your amp is going into thermal overload. Check your power connections, and make sure there are no shorted wires. Hope this helps.
Apr 21, 2010 | Fusion FEW12PK Car Subwoofer
Green power light on JL Audio 500/1 but no output
Its the power transistors that would be affected by low voltage. It delivered till it finally gave up 'cos the output wattage to be generated at low voltage means more current flowing through the equipment. This high current will adversely affect all small solenoid valves & transistors and IC's. Even failure of one section of any IC is rarely detectable with the naked eye. It has to be thoroughly checked with a multi-meter to assess the damage correctly......sodeep
Jul 30, 2009 | Jl Audio 500/1 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Keith
I had the same problem as you. The problem is the wiring from your speakers to your amp TRIPLE check your wiring. Make sure that none of them got disconnected or connected to the wrong wire.
Mar 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp turns on but there is now sound
Check this out: http://www.techlore.com/article/14696/
Aug 14, 2006 | Jl Audio 500/1 Car Audio Amplifier
73 people viewed this question
 Grubhead
Grubhead
