Question about M-Audio M Audio Keystation 88es 88 Key USB Midi Controller
M-audio ProKeys 88sx -- all led lights flash, no sound Upon turning the keyboard on, all led lights on the top panel flash. No sound from the keyboard. Is there a re-set button or something?
  • M-Audio Master
  • 5,603 Answers
I have two of these. First thing check your power adapter for output. Just because LED's are on doesn't mean there is correct voltage... There is no reset button... Cycling power serves to reset it.
ALSO check the power input connector... sometimes those get intermittent and break connection due to vibration and initial current surge when turning on.
Posted on May 31, 2010
No power, when i press the power button then the multi display just flash and the other leds but speaker sounds power on
1-Click and phone orders do not apply. ... Casio CTK-2300 61-Key Premium Portable Keyboard Package with Headphones, ...Yamaha PA130 120 Volt Keyboard ACPower Adaptor by Yamaha... Suite makes practicing your favorite songs more easythan ever before. ..... There's a problem loading this menu right now.
Sep 13, 2013 | Yamaha Portable Keyboard
Pitch automatically bends when i play even without me touching the pb wheel
The resting (centering) of the PB wheel has a problem. It is LIKELY mechanical in nature. You will have to open the unit to investigate or take in for servicing. If you open it yourself, have two people to help hold the two parts of the shell to avoid damaging the ribbon cables when opening.
Mar 12, 2011 | M-Audio ProKeys Sono 61-Key Portable...
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
Now I get an anoying delay: every time I press a key it doesn't inmediately play the sound. and i get a buzz sound when i press a key too. my pc is windows 7 inspiron 1545
If this is used to generate sounds using your computer, the problem is most certainly in your computer software. Common causes are antivirus and blockers that insist upon processing every bit of data including that from devices like this. The delay to do so is unacceptable as these anti things use mass amount of computer resources. Also if you have a wireless internet link active, that sucks processing time... Turn all of these computer resource "hogs" off and see if the problem goes away...
Nov 28, 2010 | M-Audio KeyRig 49 49-Note USB Keyboard
Try to get the keyboard to play through out my speackers
Since this has no audio output it will depend upon your computer to generate the sound using the audio system in the computer. You will need the driver software for the M-Audio to talk to the sound hardware in your computer and configure that to accept the MIDI inout from the M-Audio.
You will need to OPEN the volume and mixer controls for your sound board, unmute it, and enable the SYNTH channel and select "general MIDI".
As a test, download VanBascoe's Karaoke thing and play MIDI files to make sure your synth software is working. Then assign the MIDI source to teh USB input from the M-Audio.
Nov 01, 2010 | M-Audio Oxygen 49 USB Midi Controller
I have connected my casio to pc but pc songs and piano sound is not hearing in pc how it will work if any driver will use tell me about that i have casio ctk-2100 electronic keyboard
ASSUMING you have a MIDI interface connection, (not audio) then you need to set the PC to use a general MIDI sound and turn on the synth in the PC.
Go to control panel and open the sound icon. Select the device to use for MIDI playback in the appropriate section.
Sep 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Prokeys 88 flashes 888 and none of the keys work.
Reset the 88 by switching off --> hold the - and + buttons while turning on. Your device will reset and usually everything should be solved.
Aug 29, 2009 | Music
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Open Questions:
M-Audio M Audio Keystation 88es 88 Key USB Midi Controller Logo
844 people viewed this question
Top M-Audio Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Electro Med Services...
Are you a M-Audio Music Expert? Answer questions, earn points and help others
