Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Oil Filter Removal
To remove oil filter rotate to the left?
    Scholar:
  • 41 Answers
Oil filter removal is counterclockwise when viewing the filter from the top. Filter install is clockwise. If this is a original filter, then it will be very tight. Before installing new filter, ensure that you place a bit of new oil on the seal located on the flat portion of the new filter before reinstalling to ensure it is sealed, and it also only needs to be hand tight.
Reply if you have questions!
Chip
Posted on May 31, 2010
  • 4,102 Answers
Hi the oil fiilter will undo to the left or anti clockwise how ever it may be tight as the rubber seal tends to weld itself stuck so you can eiter buy a oil filter removal tool or you can stab a screwdriver through the middle from left to right so as you can use to to undo the filter so if you have room to get a screw driver through the side of the filter then push the screwdriver through one side and out the other then use this to remove the filter doing this should free it up.
Now when you put the new filter on make sure you put some new engine oil around the rubber rub it on with your finger so that the new rubber on the filter is coated in new engine oil doing this will ensure its sealed properly and should ensure that you have no leaks.
Locate oil sending unit on 1991 Chevy s-10
The oil pressure switch is mounted to a fitting in the left rear of the engine block.BY THE OIL FILTER.Here's a link to what it look's like.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disengage the switch connector.
  3. Using J-35748 or an equivalent wrench, carefully loosen and remove the oil pressure switch.
  4. Installation is the reverse of removal.
Sep 12, 2013 | Cars & Trucks
Where is the oil filter on audi a6 tdi 2004
The oil filter is placed on the left rear side of the engine. See pictures below:
After engine cover removal:
In the above picture the oil filter was removed, (green arrow).
Sep 24, 2011 | 2005 Audi A6
Where is the motor oil drain plug on flxh
This is straight from the repair manual:
1. Ride vehicle until engine is at normal operating temperature.
2. Locate oil filler plug/dipstick on right side of vehicle at top
of transmission case. To remove the oil filler plug, pull
steadily while moving plug back and forth.
3. Locate oil drain plug at front left side of the oil pan.
Remove the oil drain plug and allow oil to drain completely.
4. Inspect the oil drain plug O-ring for cuts, tears or signs of
deterioration. Replace as necessary.
5. Remove the oil filter as follows:
a. Obtain the OIL FILTER WRENCH (HD-42311). The
tool allows easy removal of the oil filter without risk
of damage to the crankshaft position sensor or
cable.
b. Place the jaws of the wrench over the oil filter with
the tool oriented vertically. See Figure 1-1.
c. Using a 3/8 inch drive with a 4 inch extension, turn
wrench in a counterclockwise direction. Do not use
with air tools.
NOTE
Use OIL FILTER WRENCH (HD-44067) if HD-42311 is not
available.
6. Clean the oil filter mount flange of any old gasket material.
7. Lubricate gasket with clean engine oil and install
new
oil
filter on filter mount. Hand tighten oil filter 1/2-3/4 turn
after gasket first contacts filter mounting surface. Do
NOT
use OIL FILTER WRENCH for oil filter installation.
NOTE
Use of the Premium 10 micron synthetic media oil filter is
highly recommended, Part No. 63798-99 (Chrome) or 63731-
99 (Black).
8. Install engine oil drain plug and tighten to 14-21 ft-lbs
(19-28 Nm).
9. With vehicle resting on jiffy stand, add 3-1/2 quarts (3.3
liters) engine oil as specified in Table 1-1. Use the proper
grade of oil for the lowest temperature expected before
the next oil change.
Apr 05, 2011 | 2008 Harley Davidson FLHX Street Glide
What way do i turn the oil filter to loosen the oil filter
All oil filters turn counter clockwise to loosen.
Mar 20, 2011 | 1993 Mercury Cougar
Information on how to remove oil filter housing
Removing your oil filter housing is a simple task with the correct tools. You will need to evacuate the oil in the drain pan before removing the filter housing. You need a torx bit to remove the housing. The oil filter housing is located near the distributor cap. You can unbolt the housing by unscrewing the torx bolt on the outside of the neck. The filter and the housing will come out.
Read more: Jeep Oil Filter Housing Removal ' eHow.com http://www.ehow.com/way_5649355_jeep-oil-filter-housing-removal.html#ixzz1CS95qEdH
Jan 28, 2011 | 1999 Jeep Cherokee 4WD
Where does the oil come out of a 2004 Yamaha 1100 VStar Classic
Oil drain plug is located near the bottom of the engine, left side toward the front. The oil filter element is located on the right side of the engine under the cover toward the front. Changing the oil filter usually requires removal of the front exhaust pipe. There is an aftermarket filter relocation kit that replaces the filter element with a spin on filter that mounts on the front of the bike.
Jul 11, 2010 | 2004 Yamaha V Star Classic
Need to remove external oil pump on a 95 ford tauras 3.8 v6.what all is involved doing this??
Oil Pump
Removal
  1. If necessary, remove oil bypass filter (oil filter).
  2. Remove oil pump and filter body to engine front cover retaining bolts and remove oil pump and filter body from engine front cover.
  3. Inspect oil pump body seal (6C639), oil pump and filter body and engine front cover for distortion and wear. Replace components as necessary.
Installation
  1. Position oil pump and filter body on engine front cover and install retaining bolts.
  2. Tighten the small engine front cover retaining bolts to 8-11 Nm (71-97 lb-in) . Tighten the large retaining bolts to 23-32 Nm (17-23 lb-in) .
  3. If removed, reinstall oil bypass filter (oil filter).
Dec 04, 2009 | 1995 Ford Taurus
Location of oil filter on a VW 1.9 TDI passat 2003
WELL THAT YEAR DOSE NOT COME WITH 1.9 BUT ANY WAY IT SHOULD BE UNDER CAR NEAR RIGHT AXLE OR LEFT SOME TIMES
Aug 31, 2009 | 2003 Volkswagen Passat
Oil filter removal / oil cooler install
There's an easy way for your next filter change - use a K & N filter, they have a nut on the end.
Nov 20, 2008 | 2003 Harley Davidson FXDXT Dyna Super...
Nov 20, 2008 | 2004 Harley Davidson FXDX - FXDXI Dyna...
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
189 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
