Question about Sharp LC32D47UT 32 in TV
TV turns on for brief moment, then shuts off.
TV turns on like normal, it presents the channel the tv is currently on, you can hear the volume kick in, but in a matter of a couple seconds the TV shuts off leaving the power button blinking green. When I hold the power button down for a while I get the light to turn yellow, then red, then completely off again. I've tried anything I can think of to somehow reset the TV, but nothing has worked.
4 Suggested Answers
  • 8457 Answers
SOURCE: green blinking light tried the reset unplugging
U have sound but no picture?Ur lcd inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: I am currently working on a Sharp Lc37sb24u. I was
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Oct 27, 2011
Zephyr0u812
  • 27 Answers
SOURCE: green power light blinks, tv won't turn on more
You may also have one or more bulbs out. Mine had three out, which makes the inverted detect a fault and triggers shutdown. I painstakingly adapted the clips from the old bulbs onto ones from another 37" tv. I hear that you can buy them for $13 each. I am not sure where though. I just bought a 'cracked-screen' 37" on Craigslist for $30 and retrofitted the lamps.
Posted on Nov 25, 2011
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
It coming on and after a couple of seconds cut off
Without a brand AND model number or a better description of the problem, any suggestions would be nothing more than a guess.
Unless you are prepared to repair the TV yourself, professionally performed repair, even simplest ones, will probably exceed the cost of a new LCD replacement set.
Due to X-ray and other safety concerns (equipment and/or people), CRT TVs constantly check the voltages and signals required to make a CRT work. A few seconds grace is allowed during start up but after that, any excessive high voltage (real or imagined) or loss of beam deflection circuits will cause the TV to turn off.
Please do the following:
1. Move the TV to a quiet and preferable totally dark room.
Wait until night if necessary.
2. Stand within an inch or closer to the TV screen.
3. Turn on the TV and look and listen for the following:
a. Whoosh sound and/or head hair attracted toward TV screen
Yes. High voltage activated and charged CRT screen.
No. High voltage failed to activate.
b. Hissing or normal sounds from the speaker(s) while set is on.
Low voltage circuits probably okay. Defective low voltage regulator can cause high voltage to exceed limits.
c. Entire screen briefly lit up or single bright spot at center of TV screen
High voltage worked for a moment then the TV shut off due to over voltage or current problems.
d. Brief bright line from top to bottom or single bright dot on TV screen
horizontal deflection circuits bad
vertical deflection circuits ok
TV shut off due to bad deflection/sweep circuit
e. Brief bright line from left to right on TV screen
It would be helpful for you to perform the above "up close and personal turn the TV on test" and report what happened.
Nov 26, 2014 | Televison & Video
Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Nov 28, 2012 | Televison & Video
Black Screen
Now turn on tv.Have picture flicker few sec.than dies,have sound only left?Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites liike shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 17, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
Picture goes off after a brief display on the screen.
dear,
check the flyback. did u hear any noise coming from that ..
regards
Sep 25, 2008 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | JVC AV-27F702 27" TV
Sharp LC32D47UT 32 in TV Logo
175 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
