Question about Hayward SAND FILTER, PRO SERIES
Hooking up five hoses to my hayward pump/filter
Does anyone know how to hook up the five hoses from the hayward pump to the pool?
  • 8,404 Answers
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
Posted on Jun 03, 2010
Show diagram on how to hook up hoses on ST180 sand filter
skimmer to intake front of pump top hose from pump out to in of filter out of filter return to pool return
Jul 30, 2013 | Hayward Pool & Spa
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
Water is running out the waste valve when the pump is running and filter is set on filter. How can I get this to stop?
You may need to disassemble the top of the multivalve, make sure the handle is 180* to the "Cam"
Jun 14, 2012 | Hayward SAND FILTER, PRO SERIES
Show how to hook up hoses to sand hayward filter
Here is a copy of the users manual for these pool filters. Page 5, specifically, should help you because it has a diagram of the filter and where the hose connections are. It should have everything you need to get it set up properly.
http://www.backyardcitypools.com/images/hayward/side-mount-filter-manual.pdf
Jul 12, 2011 | Hayward SAND FILTER, PRO SERIES
I have an above-ground Hayward sand filter that I'm trying to hook up. I can't remember how to connect the hoses and have been trying to find a diagram (photo) that shows. Can you help?
If you look closely at the plastic near the threaded ports you will see Pump, Return and Waste. Pump is the hose coming up from the pump discharge, return goes back to the pool or to a heater or other accessory if you have one and waste is the backwash line.
John
May 03, 2011 | Hayward SAND FILTER, PRO SERIES
Hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
Use of pool vacuum
Try consulting the owners manual for these pool filters for more info. I can tell you that you need to have your valve set to rinse for normal vaccuming and waste for heavily soiled pools. Hope this helps.
May 04, 2010 | Hayward SAND FILTER, PRO SERIES
Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
How do I connect up a hayward pro grid de4820 to a pool pump
motor gets hooked to bottom ,top is outlet back to pool there should be a bottom drain plug hose to pool goes on top return and on pump inlet
Jul 13, 2009 | Pool & Spa
Pool need to know how hoses hook to pool
from the skimmer to inlet pump -from outlet pump to in let filter -from out let filter back to pool return
May 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
519 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
