Question about Whirlpool Ovens
Whirlpool electric single oven error F-7
Whirlpool electric single oven part #8101P104-60/4381517 error F-. What does that mean?
Skill Will
  • 53 Answers
SOURCE: whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Posted on Apr 02, 2008
  • 18 Answers
SOURCE: Whirlpool single electric oven - model unknown
Turn the breaker off that supplies the power to the oven for 5 minutes to allow the computer to reset. If this doesn't work you my have a bad board.
Posted on Aug 04, 2008
  • 22 Answers
SOURCE: Oven has power; wont heat
It's mounted on the rear of the oven. First, turn off the circuit breaker, then the oven must be removed and the back panel taken off to access the TOD (thermal overload device). Its mounted right flat against the oven rear panel, with one large red wire attached on each end. If the TOD is open, that means the rear of the oven got too hot or the TOD failed (its a safety device). You can connect the two wires together and insulate with electrical tape, restore power and test the heaters to make sure the TOD is actually the problem. They haven't ever solved this problem...the most current answer is to replace the TOD with a new one, but bend the mounting tabs so that when the new part is installed, there is a space between the TOD and the oven sheet metal about the thickness of a dime. Then reassemble and reinstall the oven.
Posted on Apr 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: F1E1 error on my whirlpool oven. What does this
F1-E1 Defective ERC Replace ERC
ERC= electronic oven control
Posted on Jun 28, 2010
  • 84 Answers
SOURCE: Problem for Whirlpool RBS275PD Electric Single
An E6 F2 error code on these parts has always been due to the control board. These controllers can be repaired quickly and reliably at www.fixyourboard.com If buttons are not working or you get an F2-E0 or F2-E1 then it is the keypad
Posted on Nov 03, 2010
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
Error E# and F1
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued
SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for.
Check the jumpers in the harness to make sure they agree with the actual oven size.
Thanks
Jun 01, 2010 | Whirlpool RBS245PDS Electric Single Oven
Error code EO -F2- Any one know what this means
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
May 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool wall oven model rbs245pdq12
Adjusting circuit board settings for oven size.
Apr 27, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
56 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
