Question about Goldstar GW-HD5000 Window Air Conditioner
Unit turns on no cool air comes out even when setting is on high
    Genius:
  • 1,044 Answers
1 Please remove th back cover and check if the cooling pipes are getting cool when the air conditioner runs. If there is no cooling /moisture deposit on the pipes it means there is no gas in the air conditioner. Get that checked up. Refill the gas after getting checked up that there is no leakage.
Posted on May 31, 2010
I have a Whirlpool Model ACQ158XPO wall/window air conditioner. Motor comes on but it does not cool. Any suggestions?
Its really tough to troubleshoot window units without pulling the cover off. If I was standing there looking at it without tools in my hand I would first make sure the fan/cool switch was in the fan high cool mode and that the thermostat was turned all the way to the coolest setting. Beyond that it needs to go in for repair. Wish I could be more help. Good luck.
Oct 05, 2014 | Whirlpool ACQ158XP Wall/Window Air...
Front unit high cool and high fan not working
just replace the fan ..... its seems there is some voltage problem
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
What would cause this AC Unit to not be able to cool a room of 264 sq ft even if left on all night, and then during the day it loses its cooling capacity?
A couple of things could cause that problem;
1. A dirty or clogged air intake filter. Remove, check and clean the filter if necessary.
2. The unit is operating in Dehumidifier Mode rather than AC Cooling mode. Check the settings on the control panel. If in Dehumidify Mode, the AC will not turn ON, but the fan blower will remain ON.
3. A clogged exhaust hose to the window. Remove the hose and check for obstructions.
4. The temperature setting on the Control Panel may accidentally be set to high. Check the temperature setting.
The 4- things listed above are where you need to start troubleshoot the unit. If One of the is not the problem, the compressor may need a recharge of refrigerant. Depending on how old the unit is.
Hope this helps you to troubleshoot and solve the problem. Please let me j=know. Thanks.
Jun 08, 2011 | Danby DPAC120061 Portable Air Conditioner
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
Unit will not come on at all has voltage to unit and to contactor?
Sounds like you lost the refrigerant charge. Low pressure switch will not let compressor run. Look for oil around the condenser tubes. If you find it, this is probably the leak source.
Jun 01, 2009 | Heating & Cooling
No cold air and motor works intermittingly.
the fan motor is stuck take front cover off reach inside and turn fan by hand then try agin let me know
May 25, 2009 | Maytag M6X06F2A Air Conditioner
Heating & Cooling Logo
163 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
