Question about Blaupunkt Car Audio & Video
Installation manual RD4 X3 N1
I am drivng A Citroen C5 from 2006. Build in I have the Blaupunkt Autoradio type RD4 X3 N1 KML VA. On the Rear there are two line in connections AUX1 and AUX2. AUX1 is connected to the build in Bluetooth set. AUX2 I want to connect to the lineout of an MP3 player. (actually my tomtom 910GO unit including MP3 facilities) I bought the special connecting MP3 kabel set (9706AG) through my Citroen dealer and tried to connect it according the specifications. With the dealer we tried to enable AUX2 and set it to classic as instructed, but when programmed the software refused to store the information, while it does work for AUX1 line input. So it seems this radio model does not support AUX2 connections. There is however a CD changer connection. I am looking for a way how to connect my line in audio to the CD connector. Does anyone have an overview/connection manual which describes the CD connector pinout? Which pins are for the audio? can this be used without connecting the complete CD changer unit? your help is greatly appreciated! regards, H.P.S. van Lohuizen.
  • 13433 Answers
SOURCE: MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Posted on Feb 11, 2008
c renner
  • 43 Answers
SOURCE: how to remove the cd player from Honda odyssey EX 2002 model
The trim panel that surrounds the radio and contains the climate controls and possibly 1 or 2 other switches needs to be removed. Apply gentle, even pressure on the edges and gradually move to the other edges, and the clips should pop out.
I would advise against unplugging the climate controls or radio however other switches can be unplugged safely.
Once the panel with the climate controls is removed there should be 4 phillips head screws holding the radio in place; remove those and you should be golden.
Posted on Feb 21, 2008
SOURCE: Clarion DRX9375r AM/Fm/CD Headunit optical output question.
I have the same HU and the same processor as you. First I only used the chinch cables to the processor, and from the changer.
The improvements you make; your headunit DAC and your chancher DAC wil not be used anymore. The differens; normal with a cd you convert a digitalsignal into analoge, in the HU or changer, and then you make it digital again in the processor, en put the signal analoge into your amp.
The advantage is; the processor uses the famous Burr Brown DACs and that is know by its good sound processing.
cheers mate
Posted on Apr 08, 2008
scott201201
  • 170 Answers
SOURCE: Video Connection for NECVOX RE-7269
PV AMERICA, INC.
Address:13157 Flores St., Santa Fe Springs, CA 90670
PHONE: 562-941-8368
FAX: 562-941-8180 / 626-333-7683
EMAIL: INFO@NECVOX.COM
http://www.necvox.com
Posted on Apr 12, 2008
SOURCE: Sanyo 8 pin din cable
from Sanyo LA,Calif
Posted on May 11, 2008
Hi do you have the radio code for a Siemens VDO RD4 N1-00 radio s/n VDAPVF60130271 thank you chris
Im guessing this is the radio code for a citroen radio you require? If so contact this link with the radio serial number and for a small fee they will send you the code: Car radio codes in Uxbridge London Gumtree
Jul 30, 2017 | Car Audio & Video
Code for Blaupunkt RD4 N1-02
for code go to dealer with vin or vehicle and proof of ownership
Oct 15, 2016 | Blaupunkt Car Audio & Video
I lost the code for Blaupunkt autoradio cr 43
Blaupunkt radio codes emailed to you from this link, I have used them before, 100% guaranteed to work and i can recommend them: Radio Codes United Kingdom Gumtree
Jan 02, 2016 | Blaupunkt Car Audio & Video
Manual Autoradio LG LDF900UR.
I can't find a digital camera from this type Autoradio LG LDF900U. I could find a car radio of that type.
If the link wont' work, google for LG LDF900UR manual. Don't try a european site, because they try to block free downloads. In the USA it is more easy.
try this link
Nov 26, 2013 | LG Cameras
Blaupunkt rd4 n1-02 making bleeping noise every second,
This usually happens with VIN coded radios that are fitted into a car other than the one it was electronically linked to.
If this radio has just been fitted into a different car then it is a job for the Main Dealer or a Radio Decoding Service to electronically link it to the new vehicle.
Not available for free
Jun 18, 2011 | Car Audio & Video
Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
May 29, 2010 | Car Audio & Video
Interference on Blaupunkt RD4 N1-02
Is it an loud sharp sound which varies according to your speed? May be a power problem - crossing lines. Take it by an auto stereo shop and ask the installer. Make sure they sell your brand. Someone would have to hear the sound in order to fix the problem. Hope this helps!
Mar 16, 2010 | Audio Players & Recorders
Citroen audio manual
botton 1 is the first digit, button 2 is the 2nd and so on after all 4 done press 6
Oct 12, 2009 | Car Audio & Video
Car Audio & Video Logo
1,749 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
