Question about Acer Aspire™ T180 PC Desktop
White and red box saying out of range
Help plz
  • Acer Master
  • 11,800 Answers
The resolution of the display is set higher than what your monitor can support. Boot into Safe Mode, Right click on display, Properties, Settings, at Screen resolutions select the default resolution of your monitor 1024x768 or 1280x1024, depending on the version .
Posted on May 31, 2010
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Should I use 6 2 wire or 6 3 wire to my breaker box to hook up my range
You MUST use 6-3 wire and quite obvoiusly at the breaker box the red and black wires go onto the breaker and the white wire goes onto the netural bar/buss
Jul 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a leviton programable timer no.vpt24 Your instructions show two wires in the junction box. I only have one wire.I can join the black to black white to white but no wire to join with red wire
I think you are saying that you have 1 romex-cable entering box.
And that 1 cable has a black, white and bare ground wires.
Here's how to wire Leviton's vpt24 timer.
Timer has Red Black White and Green wires.
Connect White and Green wires to bare ground wire.
Connect Black-timer wire to black wire inside box
Connect Red-timer wire to white wire inside box.
Turn power ON, and try timer.
If timer does not work, then reverse Black-timer and Red-timer.
Here is photo of similar wiring using Intermatic timer
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Below is copy of manual:
http://waterheatertimer.org/pdf/VPT24-single-or-3-way.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Hammering
Replacing an old electric range that was hard wired (8 gauge), red, black and a bare wire. New range allows hard wiring, but the terminal block has connections for black, red and white (neutral). Can I...
White to bare wire, the bare wire runs to the common or ground in your breaker box.
Your black to black should go to a breaker in your panel.
The red to red goes to same breaker but to the opposite screw. 1 leg is from 1 side of buss bar and 1 from the other each 1 carries 120volts giving you 240 at the stove.
This can go as low as 220 and you will be okay.
ANYTIME WHEN WORKING WITH ELECTRIC TURN BREAKER OFF!!! TEST TO SEE NO POWER IS AT YOUR WORK!! LOCK THE BOX SO IT CAN NOT BE TURNED BACK ON!!
THANK YOU
May 19, 2010 | Kitchen Ranges
Need to re wire drop in range my wires r red white and black your wires r red and black wich two colors should i combine
The RED and the BLACK wires are the HOT leads. This means they each have 120VAC on them. You simply match the corresponding colors (red to red, black to black). DO NOT connect them ALL together. The WHITE wire is neutral (0 VAC). In a 3-wire configuration, the neutral is grounded to the equipment cabinet. The following link explains:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Let me know if you have any questions. I hope this helps you.
Dec 22, 2009 | GE Profile 30" Self-Cleaning Drop-In...
I need to install a kenmore range. the wires coming from the range are red, white, black, and green. The wires coming from wall are black, white and copper. How do I connect the wires?
Hello, Here's how to hook it up:
Black from wall to black at stove.
White from wall to red at stove.
Copper from wall to white and green at stove.
Hope this helps. --W/D--
Jul 31, 2009 | Kenmore Kitchen Ranges
Just purchased new electric stove. The old stove had been hard wired. Black, white and copper. The new stove is asking to connect red, white and black. what should i do ?
Normaly black, white, copper (ground) is a 2-wire 110 volt, black white, red, copper is a 3-wire 220volt circuit. You must have a 3-wire cicuit run from circuit breaker box to stove connector.
Apr 28, 2009 | Kitchen Ranges
Wire a 4 prong l dryer box
First with any electrical repair, safety must be observed. Be sure the circuit is turned off at the breaker panel (check wires with a voltage tester)
quality gloves and eye protection should be worn.
Typically the terminals or screws in the plug will be color coded (2 brass, 1 aluminum & 1 green)
The black and the red are both hots and can be connected to either of the brass terminals.
Red - hot = Brass terminal
Black - hot = other Brass terminal
White - neutral = aluminum terminal
bare copper - ground = green terminal
I hope this helps...
Aduz
Mar 14, 2009 | Leviton 2 Gang Range Or Dryer Switch Plate...
I have a three wire lead out of my junction box (bare wire ground/white/black)and my new GE JTP 30 electric oven has a four wire (extra red). What is the wire configuration needed for reinstalling?
hook from the range the green and white wire to the bare copper wire from the house
hook the black wire from the range to the black wire from the house
hook the red wire from the range to the white wire from the house
Apr 24, 2008 | Kitchen Ranges
Acer Aspire™ T180 PC Desktop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
