Question about Liebherr KIKNV3056 Bottom Freezer Refrigerator
The ice maker appears not to be working can not
The ice maker appears not to be working can not find user manual is the ice maker light supposed to be on or off?
  • Liebherr Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 30, 2010
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | GE Refrigerators
Water leaking into refrigerator from freezer
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When the Ice Maker Leaks
1. Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
2. See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
3. Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
I hope this would help.
Thanks have a good day : )
Apr 12, 2011 | Kenmore Refrigerators
Our ice-maker stopped working on the hottest day of the year!
heatman101
klhggkllkg
Jun 01, 2010 | Maytag MZD2766GES Side by Side...
User manual for GE Ice Cream Maker Model 106765
Hi
Thanks for using FixYa. You can download the user manual for GE Ice Cream Maker Model 106765 from the following link—
GE Ice Cream Maker Model 106765 User Manual
Please do rate the solution.
Thanks
Rylee
Aug 22, 2009 | Gel Canister 106765 1.5 Quart Ice Cream...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Feb 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Liebherr KIKNV3056 Bottom Freezer Refrigerator Logo
1,411 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
