Question about Dishwashers
I accidently bought jet dry cleaner and not jet dry rinse aid and i put it in the rinse aid. what will happen to my dishes. How can i get it out. I have 3 young children i do not want harmed from using my dishwaher. will it harm them if i use the dishwaher?
  • 2,651 Answers
Jet dry cleaner??? im thinknin its also a dishwasher detergent???if so i wouldn 't worry about at all, no way to empty the dispensor, it will dispence on its own over the coarse of a month. but yea so long as its a dishwasher detergent i would not worry about harm to family
Posted on Apr 09, 2008
I have Whirlpool WDT720PADM I bought this year 2017 (2 months old). Dishes are coming out clean but slimy when touched.
sorry but FIXYA has no fix for this . check with the manufacturer's website and tech support
Nov 30, 2017 | Whirlpool Dishwashers
I have a kenmore elite ultra clean dishwasher. Have only used it two times. Does not dry well. Lots of water left Read Manuel. Extra dry should not always have to be used. Water still on door after a...
RINSE AID! Buy a bottle of Jet Dry or similar rinse aid liquid. Fill the rinse aid dispenser completely. Run dishwasher as usual. Water will no longer cling to the tub or the dishes. Newer dishwashers require rinse aid to dry properly due to reduced energy consumption.
Aug 07, 2014 | Dishwashers
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 | Dishwashers
My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
The Cascade is the detergent powder and will not help the dishes to get dry.
Note: Even with the rinse aid full, some plastics will still be wet.
Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
255 people viewed this question
Top Dishwashers Experts
