Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven won't heat, display out, gas burners on stove
Whirlpool oven won't heat (stopped in middle of preheat), display went out, gas burners on stove top still light
  • Anonymous Mar 23, 2014
    Ovens ignites and heats, stove top doesn't ignite, LOC is displayed thou but no lock symbol is displayed
  • 327 Answers
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
Posted on Jun 02, 2010
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
Oven takes long time to preheat
if the oven has a glow bar it,s not staying hot enough to keep the main burner on change the glow bar
Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Oven slow to heat and top burners weak flame
sounds like you have a gas pressure /flow problem. id start with hte gas company have them come out and check you tank pressure(if using LP), or the pressure from reguator leading to home
Mar 13, 2008 | Ovens
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
145 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
