Question about Thermador C272 Electric Double Oven
Error message F64 appears when lower oven is turned on.
Oven starts pre-heat cycle then turns off, beeping sounds then error message F64 appears.
Unrelated problem - after using ovens and turning them off the oven inside light turns on by itself. It cannot be turned off unless the oven is restarted and the turned off.
Mort in Encino
  • 4 Answers
If you look under the bottom door you will see a 3/4" tall slot the entire length of the door. This is where the cooling air blows out. In the middle of this slot is the air switch enclosed in a 5" long metal housing. You can see a thin metal paddle sticking out of each side of the housing. These paddles are spring loaded to angle slightly back. When the fan is on, the airflow will push the paddles forward. If they do not move forward, then you will get the error code. The simplest solution is to vacuum out all of the normally collecting dust that keeps the paddles from moving. To better access and clean the area, the black trim piece that forms the slot can be removed by unscrewing the two retaining screws. That can be more easily accomplished by first removing the lower door. This is very simple. With the door fully open, rotate the small metal clip on each hinge so it hooks over the protrusion on the other part of the hinge. Then lift up on the door (close it part way) and slide (pull) the door and hinges out of the hinge slots. There is no need to remove the entire unit from the wall.
Posted on Dec 25, 2012
  • 327 Answers
Hello,Note that lower oven cooling fan air switch not detected and that means you have to replace air switch,replace cooling fan,check connections,check P6 on PCB control display.
Thanks
Posted on May 31, 2010
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Error code F64 on lower thermador oven. Works for a minute or so then beeps and F64 is showing,
Nov 12, 2010 | Thermador Ovens
I am getting an F64 error message. what is this trying to tell me?
Welcome to FixYa.
The "F64" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the lower oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F64 error it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
( F64 can also be initiated by a failed "K4" relay on the control board, but that is less likely )
It can be accessed by way of removing that grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Let me know if I can assist you further regarding this issue and I`ll try to be available asap.
Good luck.
Thank you for choosing FixYa today, please take a moment to rate the info provided here for you.
macmarkus :)
Aug 03, 2010 | Thermador SEC302 Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Thermador C272 Electric Double Oven Logo
539 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
