Question about RCA HD61LPW175 61" Rear Projection HDTV
When i turn my tv on it makes a loud non stop noise
YOU HAVE A DEFECTIVE FAN OR COLOUR WHEEL
Posted on May 31, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Loud static noise without warning
this problem come due to memory ic faulty contact service centre for memory is
Jun 04, 2010 | Philips 47PFL7403D 47 in. LCD TV
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
Samsung DLP HLR5667wx/xaa. All sudden loud noise non stop
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set.
Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
Sep 05, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
RCA HD61LPW175 61" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
