Question about Hayward Navigator Pool Cleaner
My pool navigator will not stay at the bottom its always coming to the top to clean and hovers there.
  • 20 Answers
If by saying at the top you mean running around the top of the walls then reduce the suction on the vacuum by opening another valve slightly... if by at the top you mean floating around in the water then make sure the vacuum is getting enough suction.... it can be a number of issues causing loss of suction but most likely is going to be too many sources on suction side of pump.
Posted on Jun 03, 2010
Testimonial: "That did it thanks for your help"
  • 4 Answers
The rear flap on your cleaner hasan aqua colored flat head adjustable screw. This will position the flap in one of three settings. abc. These determine how it climbs. Adjust accordingly and set your suction using the vacuum gauge device provided when purchased.
Posted on Jan 06, 2016
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
My phantom remains on the water's surface and will not dive to the bottom of the pool. What do i need to do to have the phantom clean the bottom of the pool?
There is a switch on these pool cleaners that has options "top, bottom, and automatic". If you have the cleaner set to automatic and it is staying on the surface, try changing the switch from the automatic setting and put it on "bottom" until you get the bottom clean.
May 12, 2011 | Hayward Phantom Pool Cleaner Complete with...
G4 keeps heading for and climbing the sides of the pool, always making a long run along the side walls of the pool. The bottom is not being cleaned. Have adequate lenght of hose. Diaphram has no holes....
If these pool cleaners are staying on the edge on the pool, there are two things that you can do to correct the problem. First, reduce the flow through the cleaner to the low side of the ideal range. Second, add a hose weight about 3 feet from the cleaner's head. That should correct the issue.
Apr 15, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Pentair Legend with boster pump dosent stay on bottom of pool. Seems to float near top of pool more than it does staying on bottom when its suppose to be cleaning.
Make sure that your wheel RPM is not greater than 32. If the RPM is too high, the cleaner will be forced from the bottom of the pool. Make sure that your back up valve is cycling properly because it, too, can cause the cleaner to lose contact with the floor. You might need to use a diverter to make sure that the pool cleaners not getting too much pressure.
Feb 28, 2011 | Pentair White/Gray Legend Platinum...
Cleaner is floating on top of pool
First, remove all of the air from the cleaner head and stop all air from entering the pool2_bing.gif through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaner to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Apr 20, 2010 | Hayward Navigator Pool Cleaner
My Kreepy Krawly always gets stuck!
You will get a current going in the pool that will drive the cleaner into some spots that it can't get out of. The steps are a good spot for this.
If you move the return eyeballs around usually point them down this will help. This will stop any action on the surface of the pool as far as pushing things into the skimmer but the action of the hose jiggeling should help to break the surface tention of the pool and get leaves and such to sink so the cleaner to pick them up.
If you don't have eyeball returns then you can get dirveters that slide into the return lines to break these currents for you.
Hope this helps and good luck.
Feb 12, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krawly stays on the side of the pool and wont clean the bottom.I have placed the weights in the correct position. Any suggestions?
Try no weights.
Try weights in a incorrect position.
How is the hose....is it flexible......is it steering it to the sides and keeping it there?
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
Hayward navigator is a piece of junk.
Try useing THE POOL CLEANER im in the pool industry and switched to these due to always having to perform repairs on the navigator
Jun 14, 2009 | Hayward Navigator Pool Cleaner
My navigator falls over backward and can't recover. It usually happens when it comes up against the sides of the pool. It always happens when not running. It will rotate to change directions, it's just...
I would first make sure that your pool cleaners shoes and wings are in good working order. If they are worn or damaged, replacing them should correct the problem. You might also need to check the tension in the rear flap.
Jun 10, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
517 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
