Question about Samsung LN-T4671F 46 in. LCD Television
My TV does not start easily. It gives slow "tick tick" sound some six times before it comes on. Any adjustments to help?
DEFECTIVE POWER SUPPLY
Posted on May 31, 2010
How do i fix my 2001 740i bmw it makes a ticking sound win idleing
could possibly be a lifter tapping (Ticking) ,depending on how many miles the vehicle has on it might be time for lifters to be adjusted,most foreign overhead cam engines must have lifters adjuster periodically ,if you turn on the air its puts more of a load on the engine causing a louder sound (also check oil level an engine low on oil will start to tick too.. the more wear the engine gets the looser the lifters can get over time ,look in your service manual if you have one and see what the intervals are on lifter adjustment this can give you an idea.
possible only if
the ticking sound is coming from the top of the engine usually comes from under the vavle covers where the lifters are located,
Aug 19, 2015 | BMW Cars & Trucks
My 96 eldorado is making a ticking sound, it sounds like its inside the engine. It ticks faster when you give it gas. What could this be?
Better get a mechanic to check it out before you drive it very much.
Could be a lifter or piston pin with no oil.
Oct 28, 2014 | 1996 Cadillac Eldorado
Ticking sound
I have a 300SL and I encountered a similar problem. My dash lights were not coming on, the car was not starting and there was a ticking noise coming from the passenger side(near airbag) when I was trying to start the engine. I noticed that my ignition switch was slightly getting loose. There is an adjustable cover around the ignition key ( like one inch wide) that can be easily tighten by hand. The purpose of this cover is to hold the ignition in the proper place for the electrical contact. It also has a few marks on it which show you if it is properly aligned. By adjusting it to the proper spot, I was able to fix the problem and the car starts just fine right now. Sometime (once in 6 months) it gets loose again and I have to re-tighten it, but it only takes 5 seconds to do so. It seems like the ignition switch is very sensitive on these cars and the smallest misalignment of the switch can make the car not start.
I hope this helps.
Apr 14, 2014 | 1998 Mercedes-Benz SL-Class
Hi I'm Wayne. Pls help me with my GA13DS engine
Check for a bad rocker arm and correct valve adjustment. Make sure cam timing is correct. Never try to retard or advance the cam timing.
May 16, 2017 | Cars & Trucks
I havent changed the oil in my 95 chevy corsica in about 10 months.. now i hear a loud ticking sound from my engen what could it be and can it be fix easy?
Ticking sound may come from a loose or valve tappet with too much clearance. It can be easily adjusted by a mechanic.
Nov 08, 2012 | Chevrolet Cars & Trucks
Can hear ticking sound around engine
Hello jerry...does this "ticking" sound like it is coming from the top of the engine...the cylinder head area? You can take a short piece of hose, like a heater hose or even a garden hose, place one end to your ear and the other on the engine, move it around and u can pinpoint the area it is coming from better. I would say that your valves are probably making the ticking noise and need to be adjusted. Either that or an exhaust leak around the pipe and cylinder head, If you haven't adjusted the valves they probably are due for it. I will go ahead give you the specs for them.
Valves are to be adjusted and set on a COLD engine.
Intake Valve .001 to .003
Exhaust Valve .003 to .005
As you can see this is not much of a lash...so normal wear will cause them to start making noise once they get out of adjustment. I hope this helps & good luck with your bike.
Jul 15, 2011 | 2000 Suzuki GZ 250 Marauder
My sony won't turn on. when I use the remote to turn on it flashes green six times, I hear a click and then it flashes red six time.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
Feb 20, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
The tv 'runs' - sometimes for hours, sometimes just a few minutes. cut on and off - most times you can hear a ticking - then the power light comes on and the set will. Sometimes the power light will...
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please find below two links for tips on poor start ups, as if the set is totally failed the SMPS might be faulty.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Jan 03, 2011 | Televison & Video
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
Loud ticking noise coming from motor and motor runs rough.
u didnt hurt anything,make sure u're using  multigrade motorcycle oil
Jan 21, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Samsung LN-T4671F 46 in. LCD Television Logo
307 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
