Question about Siemens Washing Machines
Siemens wdi1442 error code e06 - not draining water
Hi, I have a Siemens washer dryer model WDI 1442. It will not drain or spin out water after wash. It shows code E06.
Do you know how i can solve?
thanks
2 Suggested Answers
SOURCE: Hi, I have a Siemens washer dryer model WDI 1442.
any luck - i have the same problem
Posted on May 31, 2010
Siemens Wdi 1440 washer/dryer
It means your machine is not draining, Look out for the water exit open to drain water off.
Jul 21, 2014 | Siemens Computers & Internet
Code E13 on siemens washer
Pump may be clogged
Washer controller may not be changing from agitate to drain-spin. Check by manually advancing to spin or selecting a spin-only operation.
Sep 12, 2012 | Bosch Siemens Washing Machine Drain Pump &...
I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin...
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Washing Machines
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
I have a siemens WDI 1640 washer/dryer which is
I managed to find out the fault code E14 relates to faulty Heating element, product code 494069, and have been quoted £65.00 + Vat for the Bosch replacement. I am yet to decide on how I will proceed.
Dec 29, 2009 | Siemens Washing Machines
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
WDI12C Machine Will Not Drain - Error Code E06
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Nov 24, 2007 | Smeg WDI12 Front Load Washer / Dryer
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Oct 07, 2007 | Neff V4380X0 Front Load Washer / Dryer
Washing Machines Logo
765 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
