Question about Whirlpool Washing Machines
The lid switch on the stacking washer dryer by Whirpool is broken. I have the replacement part. In order to change the part is removing the cabinet the easiest method to get to the switch ends
  • 10,319 Answers
The top panel will have to be removed to gain access to this switch sorry to say
There is no easy way since is a stacked unit
Have a friend help you remove the top off
Posted on May 31, 2010
My stacked Maytag washer/dryer model lsg7804aam needs a new lid switch which is located in the top right rear (under the dryer of course:) The front sides of the dryer rest on some thin foam pads on the...
what you can do without harm is remove the washer front panel and tug on the top and it should pull out...you can also raise the front washer legs up into the machine and that too will make it easier to pull out...be sure when replacing the lid switch asm to replace the fuse which is on the rear of the left side washer cabinet panel once front panel is removed
Aug 24, 2011 | Maytag Washing Machines
Broken lid switch on washer
you must take the cabinet off by removeing the screws from the consloe and flip it back and remove the 2 clamp,s and remove the cabinet and replace lid switch
May 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will agitate, but not spin
there is a coupling that is behind the motor that brakes if the washer is overloaded,part number 285753A,it' around 25 bucks,it's a pretty easy job,two clips hold the pump on,remove them and pull off the pump,take out the two screws holding the motor clips on and remove them,pull off the motor and you'll see the coupling
Mar 14, 2010 | Kenmore 63942 Dryer
Whirpool Ultimate Care II - Top loading washer The water will not drain prior to the spin cylce - Please help
The lid switch is the most probablle cause for this problem.Check the lid switch lift the lid and close it if you cant hear a click replace the lid switch.
Dec 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washing machine filled with water and then stopped mid-cycle. This happened before and the repairman said it is a door switch. He removed the lid and in 5 mins moved something at the back of the machine....
the lid switch for you model is located inside the cabinet of your washer. you should be able to access it by removing the front panel. by inserting a putty knife or similar tool on the left and right side along the seam of the cabinet. you should be able to feel two small clips that hold it in place. lift up SLIGHTLY on these clips and remove one side at a time. once you have done this you may need to release the top as well, held in by two 3/8 hex screws. the lid switch is on the right. and is held in by two phillips screws and a wiring connection as well remove the two screws and the connection and replace it with a 3355458 lid switch. hope this was a help to you
Thanks
Oct 11, 2009 | Whirlpool LTE6234D Top Load Stacked...
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
Whirpool twin washer & dryer lte5243dq3 drum off center
The ltw5243dq3 is a top loading washer with the dryer stacked on top. In order to remove things
1. One the angled piece of metal that is between the dryer and the washer there will be two screws. Remove them.
2. Next open the washer lid. There will be two screws on the right side. Remove those.
3. Close the lid. There are two final screws that hold the top part of the washer in place. You can't see them directly from the front so you might need a mirror or access to the back side of your unit.
4. Slide the top of the washer forward about 1 inch. List it up about 1inch and you will see that some wires are attached. Disconnect these wires so you can take the top off entirely.
5. To remove the front panel there are two screws. One on the left and one on the right. If you look down inside in the washer you will see them.
6. Slide the front panel upwards and then you will be able to remove it.
You should now be able to see inside your washer and it should look like the attached picture.
hope that helped,
mishkin
Mar 29, 2009 | Whirlpool ET8CHEXSQ Dryer
How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Mar 14, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
