Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
Pilot lght is on but will not turn on burner - Jandy Laars Lite2 Ld 400,000 Btu Heater
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
We got the pilot lit but cant get it to lght whole gas flame
after the pilot is lit for about 30 seconds turn it to on. The rest of it should ignite within a few seconds. If it does not, you may have a bad thermocouple
Feb 10, 2016 | Heating & Cooling
How do i re start the pilot lght
You will need:
a wire hanger or something like that about 14 in long
a small clip and matches to clip to wire.
Turn red knob to off
remove small door covers (Both).
look inside you will see a tube pointing up this is where you put the match to light it.
turn red knob to pilot and push down and hold
light match and put it at end of the tube inside it will light a blue flame
remove match.
all this time holding knob pushed down
continue to hold down for 60 sec
then let it up slowly and turn knob to on
should flame up and start whole burner
replace door your done.
OR call your gas company most will light it for free
Jan 17, 2016 | Water Heaters
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
I have a Hardwick propane stove, 4 burners and oven. The stovetop burners work fine (need a match), but now the oven does not ignite despite the pilot light working fine. I have brushed the pilot light...
Hello Patrick,
WHen you turn on the oven/broiler does the size of the polot ligh increase in size??
the way it is suppose to work is...thier a small free standing polot light and when ya turn on the oven the size of the pilot is suppose to increase and heat a little bulb that is connected to a wire that is mounted to the pilot burner and when that bulb heats up it will allow the main gas to flow into the oven(not pilot burner).
If the size of the pilot does not increase it could be caused by a clogged pilot burner. the way to determine that is TURN OFF GAS SUPPLY...disconnect gas line from pilot burner and turn on gas to unit, light that tube with it disconnected from pilot burner and turn oven on and see if size of flame drastically increases...if it does turn gas off and remove and replace pilot burner
if flame sizedoes not increase the problem is going to be the thermostat
If the pilot does increase and heats the bulb on the pilot burner the problem will be with the gas valve that,that bulb in the pilot burner accathes to is bad .
now chances of the thersostat still being available is very slim if the pilot burner is clogged and needs replaced they are still available their is 2 of them one has the mounting plate on the left and one is on the right.
here is what they look like
oldtech2332_148.jpgPart number for this one is 1898-021 notice how the mounting tab is on the right
oldtech2332_149.jpgthis one is pt# 1898-022 the tab is on the left
That when performing a quick search on google is pretty much all that still available teh thermostat (would need model number) is doubtful to find also a good chance the gas valve is also no longer available
Good luck,
GENE
Oct 27, 2011 | Kitchen Ranges
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
I am able to lght the pilot but a soon as I le go of the pilot button and try to turn on the fireplace the pilot turns off. There is also wire that looks like it's bee disconnected. I think it might be...
Are you holding the pilot light button down long enough? Replace your thermocouple. I think yours is faulty. They are pretty reliable but do go bad from time to time.
Thanks for your question at FixYa.com
Feb 03, 2011 | Heating & Cooling
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
210 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
