Question about Samsung DVD-P144 DVD Player
The tv can not find the dvd menu - Samsung DVD-P144 DVD Player
  • 84 Answers
Check the back of the TV and make sure the cord is inserted properly.
Posted on Jun 05, 2010
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
How do i program my tv too play dvd player
The TV remote should have a source button on it, you need to press it and find the scart socket or hdmi connection, it should display a list of the connection that are use for your TV. Some times you can use the power on on the DVD, so have your TV on then switch on the DVD and this may change the TV to the input that you have the DVD connected to automatic-lay. If you are using a TV arial for the DVD to connect to the TV then you need to tune the TV to the channel the TV is using I think in most cases it is channel 21 on the TV.
May 10, 2014 | Disney Lightning McQueen TV
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Cant switch tv to play my dvd player. no button on menu for this
If the tv remote has a input control button(video/antenna), you should be able to play your dvd thru this .
Apr 29, 2009 | Televison & Video
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Menu screen
Simple things to double-check:
1. are the connections between the DVD and TV correct?
2. is the TV set to display using the DVD input?
Apr 23, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-P144 DVD Player Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
