Question about Fedders Y Chassis AEY12F7E Air Conditioner
Blower lockes up when u turn it on but it spins freely when
U have it off
    Genius:
  • 1,970 Answers
Mcdevito75 here, Fan Motor appears fine while running, once shut off won"t strart again, fan needs help in starting, If so replace, the fan motor. See your local A/C repair shop, they come to the house.
Posted on Jun 26, 2010
Why do i blow fuses when i turn on blower ?
blower motor is locked up either something inside cage is keeping it from turning or bearing is locked up and won't allow it to spin freely.
Motor is drawing to many amps through fuse because of resistance
Aug 08, 2014 | 1996 Dodge Dakota
Blower won't run
usually a "humming motor" indicates either a bad capacitor or a defective motor. With the power off try to spin the blower wheel...it should spin freely. If it is tight or wont spin and there are no obstructions stopping it (like an air filter sucked into blower or other debris) then the motor most likely is seized. If the blower wheel spins free then you may have a bad capacitor. Keep in mind, just because the blower spins easy doesn't mean the motor is good. I have had motors that are defective that dont seize up but most of the time the blower wheel will not spin free if the motor fails.
Oct 07, 2012 | Desa International Blower Glow Warm Wall...
I have a 99 dodge durango 5.9 there is barely any air coming out of any of my front vents. rear vents ok can feel it out the floor and defrost just not the ones on the dash.
The Dodge Durangos are known for blower motor problems. The blower motor is under the glove compartment/dash in the big black box, and so is the evaporator coil. There is a outside air filter that tends to wear out and break apart. Once this material breaks apart it ends up in the blower motor and can cause the motor to stop turning, or turn slower than normal. You will need to open the blower motor compartment under the dash and clean out any obstructions/trash and check the motor if it spins freely without much resistance. If it resists turning by hand or there is no trash and it still fails to work, you will need to replace this blower motor.
If the motor spins freely and there is no trash, you may just have a bad blower motor resistor or A/C control switch/panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 23, 2011 | 1999 Dodge Durango
ENGINE SOUNDS LIKE IT HAS A BLOWER, AND LACK OF POWER
The first thing to check is the fan, this fan has a clutch bolted to it, when the motor gets hot it locks the fan and this make it spin faster when its cold it doesnt spin as fast and this sounds lock its locked all the time, with the engine cold spin the fan it should spin a lttle freely if its tight then replace the fan clutch, to do this you will remove the fan and then unbolt the clutch from the fan and replace it, here a picture to help you understand, good luck and i hope this is helpful.johnjohn2_7.jpgjohnjohn2_8.jpg
Nov 05, 2010 | 2002 Ford Ranger Regular Cab
My ac blower does not work I tried the heat but the blower still does not work
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 18, 2009 | Heating & Cooling
Freezin ge airconditioner small window unit boughr 2008
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are, they need to be cleaned, if not, then you are probably low on refrigerant or Blower not running at full speed.
Aug 17, 2009 | Heating & Cooling
The blower on our unit works intermitently, so the AC is only cooling part of the time.
Aug 16, 2009 | Heating & Cooling
Unit turns on but it does not blow out any cooled air or any air at all. you can see that the drum inside that usually turns is not turning.
Aug 10, 2009 | Kenmore 72055 Air Conditioner
Screeching snow blower
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
Jan 14, 2009 | Toro Lawn Mower With Toro Power Tools
Agitator locks up
The agitator is supposed to turn freely one way then catch the other. in the top of the agitator there is three teeth that retract when you go counter clockwise and then when they go clockwise they come back out to bite on the inside of the agitator and then spin it. Those teeth are called DOGS. It is only when you can spin it freely both ways that you have a problem. There is nothing wrong with it. Congrats.
Jan 04, 2009 | Washing Machines
Fedders Y Chassis AEY12F7E Air Conditioner Logo
105 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
