Question about Mr. Heater MH9B Ceramic Utility
Can't get back (or anything) off MH9B (NO "X) and cannot find S/N
Manual was lost in truck theft couple of years ago. On-line MH9BX manual says to remove 4 bolts on back panel. No bolts on mine. Spring-loaded pins on each side (L & R) of handle can be pushed in allowing side panels to move out a little. What holds the bottoms of the side panels? I see plastic tabs that mesh with metal tabs on bottom of appliance. Those on one side appear to be slotted and are somewhat depressable. I'm afraid to press too far 'cause they're just plastic. Is there another secret? A resource for the correct manual?
    President:
  • 1,851 Answers
Hi Mel,
Looking closely at your model I find yours to only be listed for 100% sure but the Serial Number. BUT - I did find this on the Unit marked MH9BX. I see you have written no X but then you do not give the serial number. So here is the direct phone number as well.
HERE is that:
FORINFORMATIONREGARDINGSERVICE
Please call Toll-Free 800-251-0001
www.mrheater.com
Our office hours are 8:30 AM – 5:00 PM, EST, Monday through Friday.
Please include the model number, date of purchase, and description of problem in all communication.
As for the limited owners manual - here is the PDF link
I called their offices but they are closed for Memorial Day.
Please use this information to follow up. Have your information ready and you should be good to go.
Thanks for choosing Fixya
Posted on May 31, 2010
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
LOST LST104 MANUAL
I know it says lst104 but its mx 2000 so here is the manual http://www.docstoc.com/docs/120233043/MX2000-2500
Mar 09, 2012 | Magnavox Televison & Video
Find spare and repair manual for intrepid wood stove
Alex, I don't know how old your Vermont Castings Intrepid wood stove is, but the only available Owner's Manual is for their fairly new model Intrepid II wood stove.
A little quick history. Vermont Castings was an independent company 10 years ago, that was bought up by Majestic (FMC) Fireplace Company of Canada. About 5 years ago, Majestic went belly up and the VC line was purchased by Monesson Hearth Products. There have been some improvements to their wood stoves in the past couple of years, so as to meet the new EPA Requirements. So, this manual may show some things your stove doesn't have.
http://literature.mhsc.com/vermont_castings/manuals/2000966_Intrepid_II_30.pdf
Hope this helps you. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
How do I use the manual defrost.I have not got a manual and have no idea how to use it as i cannot see any button you press to activate it or anything else .I cannot see to find a manual on line for...
there is no manual defrost its all automatic now if u want u will have to take a panel off where the temp settings are and see if u can turn the defrost timer manually to put into defrost mode
Jan 23, 2011 | Refrigerators
No start cranks but does not fire has spark. has fuel if bypassed by relay fuses good new fuel pump a year ago has fuel replaced battery froze, has prostart remote start, been in 8 years no issues 2000...
check to see if the security light or anti theft light flashes. if that is the case, sounds like the bypass for the remote starter may be causeing the no start by tripping the anti theft system. Remove remote starter and bypass system and join any cut wires back together that may be cut for remote starter. Try starting, if theft light still flashes leave key in the on position after attempted start for 15 minutes till theft light goes solid, turn off and try again. Repeat process for three times to re-learn factory theft system in vehicle. If problem still persists, then take to your local dealer to reprogram factory theft module in the cluster.
May 31, 2010 | 2000 Chevrolet Cavalier
Have lost instruction manual - Total Body Trainer
ask at manualfox.com
they will get it.
Mar 11, 2009 | Exercise & Fitness
Mr. Heater MH9B Ceramic Utility Logo
71 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
