Question about Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
Directions on how to change a belt on a 60" Swisher Fininshing mower
5 Suggested Answers
  • 130 Answers
SOURCE: need a main drive belt for 60
they make a ajustable v-belt for problems like this.look on internet for ajustable v-belting. i forgot what it call we used it in a sawmill
if cant find get in toutch with me and ill find it for you
Posted on Jul 22, 2009
cq92
  • 184 Answers
SOURCE: i need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Posted on Aug 30, 2009
SOURCE: smaller belt on my swisher pull behind mower keeps
make sure it's not coming into contact with any sharp surfaces
Posted on Jun 27, 2010
  • 579 Answers
SOURCE: need repair manual for u11360 60 in swisher finish
Your best bet would be to go to your local dealer. They can get for you what you need, answer any questions , or print out diagrams showing you a picture of what you need.GOOD LUCK.
Posted on Jul 09, 2011
Why do the blades on my 60" swisher only engage in reverse?
I would say that you switched your belt direction. CHECK. GOOD LUCK FRIEND.
Jun 07, 2015 | Swisher Garden
My Swisher 60" trail mower, how do I adjust the belt tension idler burning belts up real fast
look in the user manual and it should tell you how tight; looks like the belt is too loose and slipping allot to burn up..
Jun 06, 2015 | Swisher 60 in. 14.5 HP Briggs & Stratton...
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
I need a belt diagram for swisher t60 trail mower
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter Logo
383 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
