Question about Sony Ericsson Z310i Cellular Phone
Electronics appliances my audio was defective.... pls help me....
  • Anonymous Jun 12, 2008
    When I am talking to somebody their voice sound muffled, and low. Should I take the phone back and exchange it for another one?
    Novelist:
  • 119 Answers
Dear bbbbdhhhhd
Please go to a service repair center if the phone is still under warranty, they will fix it for free.
If you need specific help tell us/define audio problem.
-Ear Receiver
-Voice Speaker
-External Speaker
and when it happens, ie ringtones, during calls etc..
Regards
EngineerGR
Posted on Apr 09, 2008
SOURCE:
What damage could happen if the water of a dishwasher was turned off but used disherwasher for a week
If the appliance is correct any defect wouldn't have happened regardless of whether it is an electro-mechanical or new generation of electronic appliance. Some electronic models sometimes need to clear the memory error "Doesn't take water."
Dado
Jul 01, 2014 | Ariston Technologies Dishwashers
My yamaha does'nt turn on it just blinks on then turns off right away
You have a power audio amplifier problem.The blinking is an error code,common on latest TV,audio/video and all electronic appliances. The one that you have is your Audio Power amp is defective,it needs replacement of main Audio Power IC,do check the caps too.
Dec 15, 2010 | Yamaha RX-V795 Receiver
How do I hook up an old A/V Receiver to TV when only audio out is headphone jack.
You can find a cable at your local hardware or electronics store that will solve that in one step. It has either a mini din or full sized headphone plug on one end and a pair of red and white RCA type plugs on other end. It can be really fun to have your TV audio output through your old, tough receiver. Good luck:)
Aug 20, 2010 | Proscan 40LD45Q TV
No squelch noise from speaker
would you check that the speaker wire is intact..
May 25, 2008 | Raytheon VHF 53 CB Radio
I have power going to the amp in my car but it is not puting anything out like it's not on?
If it is a new installation, it is possible that the trigger wire has not been installed or is not getting its trigger from the head unit. The trigger wire is used to turn on the unit aside from the B+12 and the ground wire. It may also be helpful to double check tight connections of the power wires.
If the unit has been in operation before and just quit recently, then it is possible for the unit to have a defect such as a blown fuse or an internal problem with its electronics. This of course would require that you be familiar with electronics circuitry and components, the use of a DVM and a soldering iron. Should a DIY be not to your liking, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 18, 2008 | Audio Players & Recorders
Crackling noise on Uniden digital 5.8 cordless phone have tried moving to another outlet but same problem
Hello ,
Its a common problem in uniden phones ... try resetting ur phone once ...
Mar 26, 2008 | Lands Phones
Motorola gm300
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Dec 08, 2007 | Motorola EM1000R Two Way Radio
Sony Ericsson Z310i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
