Question about Car Audio & Video
Flip down 10.4 lcd monitor in car, picture is upside down. what would cause this how do i fix.
techman
  • 3130 Answers
SOURCE: The picture on screen is upside down
Did this all of a suddenly switch from being correct and then going upside down? I have heard of vibrations in the vehicle that these are mounted in to cause a break in the flex cable between the unit and the TFT screen. It is also a case where this unit could have been mounted upside down or right side up, there is a switch to control the vertical selection in the hinge mechanism. this need s to be checked out. Good Luck
Posted on Jul 28, 2007
philipp
  • 217 Answers
SOURCE: sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Posted on Nov 07, 2007
playpower
  • 51 Answers
SOURCE: big trouble
please check www.playpower.com.cn
Posted on Mar 18, 2008
  • 258 Answers
SOURCE: Upside down Projection display
To flip the screen around see
http://www.howtofixanything.co.uk/howto-146.html
Posted on Jan 15, 2009
SOURCE: Tview t104fdsh overhead monitor plays picture upside down
There should be a section in the set up of the monitor to invert the screen. or maybe a invert button/reset
Posted on Mar 13, 2009
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Oct 30, 2014 | RCA 42LB45RQ 42 in. LCD HDTV
How do i flip the picture display on emerson lf320em4?
When in file viewer mode you can rotate pictures, this is in the manual and may be the cause.
May 04, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
LCD PICTURE UPSIDE DOWN
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Upside down monitor
CTRL - ALT - <up arrow> should fix you up.
Mar 06, 2009 | Dell E153FP 15" LCD Monitor
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Everything is flipped
in the video settings you will see an option that will flip it back to normal
good luck
Terry
Apr 01, 2008 | Dell E176FP 17" LCD Monitor
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
