Question about Dishwashers
3 wk old Kenmore Elite D/W will not drain. Have attempted to Cancel/drain several times. Tried short cycles. Checked twist out filter. Baffled. Help? Is there a way to manually drain? Manual no help.
  • bbqmaestro May 31, 2010
    Egg on my face! Just installed new disposal and left the knock-out plug in. thank-you for your help.
    Thanks, Hit the nail on the head the first time. Neglected to remove the knock-out plug in a new disposal. Unit couldn't drain, and I overlooked the obvious. Saved me lots of time and grief. Thank-you! Craiger
    President:
  • 949 Answers
Sorry you are having trouble, this is a good dishwasher I have the same one in my home.
In order to help I need to ask you a couple questions.
When you push cancel drain if you listen close, do you hear the drain motor running? It would sounds like a hum or buzz up front at the bottom of the machine, this would happen while the cancel drain light was on.
If you do not hear the drain motor running there is a problem internally on the machine, it is most likely either a wire came off of the drain motor (may have got loosened during installation) or the drain motor itself is defective. In this case it would best since new to have service out to repair it. It is a quick easy repair.
If you do hear the drain motor running when cancel drain is on then the issue is a clog, somewhere between the dishwasher and the drain where the dishwasher drain hose terminates is blocked. If you had a garbage disposer installed just prior to the drain problem the 'knockout' plug in the disposer may not have been removed.
Let me know if you have questions.
Posted on May 31, 2010
  • Philip May 31, 2010
    I am glad it was an easy fix!
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Washer won't drain
That is, in short: FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 has power but not starting wash.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
