Hi. Please refer to page 111 - Zone 2 & 3 configuration, page 113 to 115 - Adjusting Volume Level of Zone 2 & 3.
http://www.4electronicwarehouse.com/content/yamaha/rx-v1800man.pdf
Let me know if you need further assistance. Thank you for using FixYa.
With the way surround sound is done it will be low. To be 100% sure swap speakers to be sure there is nothing blown out.
Usually the speakers are set to give a full room surround sound set up and one speaker or zone is set to be softer than the rest.
Also try different movies or other audio. There are also test audio you can download to set the speakers. If your unit allows for separate volume it will be in the owners manual.
I do hope this gets you to where you get satisfied with your sound system. Mine does the same thing but on some movies it will swap and where was soft goes loud.
Thanks
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Zone 2 on my Yamaha rxv 1800 is outside. it is getting very little volume. I have wall volume control for outside speakers and have it turned all the way up but only insignificant volume coming out
Good response. Thanks. Problem fixed with separate zone 2&3 remote.
