Question about Wahl Sterling 3 (8800) Hair Trimmer
I need to fix my Wahl clipper model 8800 Sterling 3, that the cord when moving it goes intermittent. How do you take the clipper apart to if the cord broke inside?
SOURCE: wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Posted on Oct 09, 2007
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Where can I purchase the Wahl Wahl Hair Clipper Taper Replacement Round Power Cord 00647-500
Wahl Clipper
3001 Locust St
Sterling IL 61081
815-625-6525
OR--Electric Shaver Service 888-476-1785
Aug 25, 2014 | Wahl Hair Clipper Taper Replacement Round...
How do i fix the power cord on a wahl switchblade clipper
depends on where the cord is broken. find the spot thats come apart and cut it out, resplice the cord and your good to go. of course your warranty will be no good, but how often do they replace things that way any way. even if they do you have to wait weeks for the replacement.
Feb 04, 2014 | Wahl Switchblade Professional...
I used my Wahl clippers for my horse a few months ago and one night when i needed to use them the blades will not move, it will just vibrate is it someting with the alignment?
The blades are stuck together because you didn't lubricate them before you put them away. Oil them and force them apart with a knife or screwdriver, use the gap between them at the side.
Feb 28, 2013 | Wahl 9160-210 Corded Basic Pet Clipper Kit...
This is a very good shaving machine and i want another one
You can get these wahl trimmers from Nose Hair Trimmer, that can be used for removing unwanted hairs from nose, ears and eyebrows.
This place would provide you most attractive deals on these branded trimmers with free shipping service.
Apart from wahl trimmer, you can also get recommendations for various other branded trimmers that are hygienic, comfortable and safe to use.
lowcost2.ru_2015.05.08-12.19.02_984580_electric_shaver_nose_ear_face_hair_removal_trimmer_clipper_dlya_nosa_y_ushey_y_brovey3-lmanv4snjocb41esrne4nwpm-3-2.jpg
Dec 03, 2009 | Wahl Vision 180 Beard Trimmer
I need a replacement cord. It no longer makes a connection. The clippers are otherwise in good shape.
contact mannyssharpening@yahoo.com They are a Wahl Clipper Dealer they have the All Wahl Parts
Oct 20, 2009 | Wahl Sterling Shadow 8745 Hair Trimmer
The power cuts off when the cord is in a certain position. The problem would appear to be near the base where the ac conects to the clipper. Is this something I can fix myself?
You can take the lid off the clipper (make sure it is not plugged in) and check that the power cord terminals did not come loose. However if that is not the problem, you probably have a bad cord that needs to be replaced. If you return it to Wahl factory in Sterling, IL, 2900 N. Locust St., they will probably replace it for free.
Sep 23, 2009 | Wahl 79110 Hair Trimmer
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
Jun 08, 2009 | Wahl 8550
Wahl Sterling 3 (8800) Hair Trimmer Logo
237 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
