Question about Fisher Paykel EcoSmart GWL15
Gwl15 won't drain. - Fisher Paykel EcoSmart GWL15
  • 10,319 Answers
Here is the first step to check why it will not drain
Go to this website and read up on all information as given
It may do the trick to get your working again
http://www.associatedcontent.com/article/818989/washing_machine_help_will_not_drain.html
Also here is another website with a trouble shooting guide that may be needed
http://www.wikihow.com/Fix-a-Washer-That-Will-Not-Drain-Its-Water-Before-Going-Into-Spin-Cycle
Posted on May 31, 2010
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
My washer will not drain the water out, what do i do
Hi - its possible that the drain pump is either blocked or over heating - it really needs to be looked at - I think the GWL15 is acessable from inside - remove agitator screw in the middle of agitator - on the right side locate the housing cover (plastic with a scew in the middle - remove screw and see if theres blockages - hope this the problem otherwise replace the pump unit.
cheers
Jul 01, 2011 | Fisher Paykel EcoSmart GWL15
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Problem draining &spinning
Get the strings coins and sand out the pump and retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
