Question about Lexmark X4270 All-In-One InkJet Printer
Color ink cartridge
I have a Lexmark X4270. The color ink was working fine and has plenty of ink left. Over half full. All of a sudden it stopped printing any color and a message saying, color cartridge missing. I did all the troubleshooting solutions. Such as cleaning the cartridge and everything else. That didn't help. I still get a message telling me the color cartridge is missing. The black cartridge is fine. Please help. Thanks
    Problem Solver:
  • 17 Answers
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
Posted on May 31, 2010
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
How do you know and find the cartridge number in a x 4270 lexmark printer?
The Lexmark X4270 printer uses cartridge number 70, 71 and 75 for the Mono Ink Cartridge. For the Color Ink Cartridge it uses 19,20 and 25. You can check this link - http://bit.ly/d2bbwm if you want to purchase these cartridges. Thanks.
Aug 15, 2010 | Lexmark X4270 All-in-One Multifunction...
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X2650 All in one printing only in black
sometimes theres a setting for the printer that it sets when theres only a black cartridge try and find a place where it lets you set to print black or black and color normaly thats the problem if not let me know id be glad to help
rate me please
Mar 27, 2009 | Lexmark All-in-One Printer with PictBridge
Color printing doesn't work
chances are there is still a tape under the cartridge, ensure that you have remove the production tape prior to usage
cheers
Sep 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
