Question about Kenmore 54701 Dehumidifier
Sealed system problem, no freon in the system and the humidistat or thermastat is making the machine run all the time, need to have serviced by authorized service company for the dehum
Posted on Apr 10, 2008
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Posted on Aug 28, 2008
SOURCE: Kenmore 54501
Normal
0
When you push the power button, the blower fan comes on. In
a few minutes you should hear a second "click"--that is your
compressor starting. Do you hear that second click?
Posted on May 29, 2009
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
Sep 19, 2017 | Kenmore Dehumidifiers
Jun 06, 2011 | Kenmore Dehumidifiers
Jun 01, 2011 | Kenmore 54501 Dehumidifier
May 24, 2011 | Kenmore 54501 Dehumidifier
Mar 22, 2011 | Kenmore 54501 Dehumidifier
Sep 15, 2010 | Kenmore 54501 Dehumidifier
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
Jul 05, 2010 | Kenmore 54351 Dehumidifier
There
Here
Dehumidifier
heatman101
Jun 19, 2010 | Kenmore 54701 Dehumidifier
Jul 05, 2008 | Haier HDN655E Dehumidifier
Jul 01, 2007 | Kenmore 54501 Dehumidifier
381 people viewed this question
IS THERE A RECALL ON THIS UNIT?
Unit is 4 years old and has been used for 3 summers. Now seems to be low on charge. Coils frosts and will collect no water! All controls seem to work but I think the charge is very low. Very poor life.
POWER IS ON BUT DOES NOT COLLECT WATER. I CLEANED THE FILTER AND EVERYTHING ELSE SEEMS TO BE FINE. NOW I SEE THIS UNIT IS NOT A VERY GOOD ONE. IT IS ONLY BEEN USED TWO SUMMERS NO WINTERS. ONLY USED FOR ABOUT 3 MONTHS A YEAR. I AS WELL HAD ANOTHER UNIT THAT WAS VERY OLD BUT WORKED FINE, MY WIFE WANTED SOMETHING THAT LOOKED NICER AND NOW I HAVE SOMETHING THAT DOES NOT WORK. SO NOW WHAT DO I DO? MR. Z.
