Question about GE Dishwashers
GE GHDA485N 10CS Dishwasher that has standing water in the bottom after the cycle completes. I pulled it out and reconnected power and ran a rinse cycle. I could see that water was pumping out the clear drain pipe but there was still about an inch of standing water in the bottom. Any thoughts as to what part has failed. Does the system use a water level switch or a timed drain cycle to determine when the water has pumped out. If it is a timed cycle could a slow drain cause the problem. Thank you for your assistance.
hotuna
  • 288 Answers
SOURCE: kitchenaid dishwasher - water standing at end of cycle
How much water are we talking about? If its say less than 2-3 cups, It may be the way it is plumbed to drain. The drain line is back washing a little after everything is finished.
Posted on Dec 03, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
For the person whose plumber disconnected the dishwasher, let me guess - he replaced your garbage disposal.
Most garbage disposals have a plug that seals the dishwasher inlet by default. This plug will need to be removed. You will have to refer to your garbage disposal's documentation to determine how to do this properly.
Posted on Jun 15, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
My GE GSD4060Dss still has standing water
Make sure ur dishwasher is level if it isn't it will not drain all the water u can adjust the little legs on the bottom of dishwasher hope this helps
Apr 09, 2013 | GE GSD4060D Full Console Dishwasher with...
Water standing in the bottom of the dishwasher after the cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 04, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
After cycle is complete my dishwasher doesn't fully drain water.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film(slimy looking substance).
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 20, 2009 | GE Nautilus 24" Built-in Dishwasher
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
Dishwasher not draining
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
107 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
