Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
WD-62725 has a yellow blinking light in the status. Prior to this alarm a message came across stating the t.v. would shut down due to heat. I shut the t.v. off before it shut down.
  • Mitsubishi Master
  • 8,617 Answers
Thats the error code indicating that the filter cover ( On left side panel) is not closed properly.
Posted on Jun 01, 2010
Mitsubishi WD-73638
lamp is gone needs replacement
Jul 08, 2013 | Televison & Video
Red status light is on but not blinking and picture wont show at all???
access the self diagnosis feature by pressing the menu and device/input buttons on the tv both together and hold them for 6 seconds then counr the teo digit blink code.
Mar 11, 2013 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725, no picture, no sound from power on. Red status light blinks 1 then 3 blinks, Using device and menu buttons error code indicates 37 (DMD fan Failure). What can I do to correct this problem?
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem...
Jul 03, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Have a Mitsubishi WD-62725 that stated on the bottom of the screen the unit would be shutting down because it was getting hot. Check the filter. The unit shut down and after I checked the filter on the...
Have you tried to access the self diagnosis feature to see if it will blink a two didgit error code/ Usually when a set says its going to shut down its due to the thermal fuse or the fans.
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Tv won't turn on, power led just flashes
I have the same problem. After about 2 seconds the system status light blinks red and the system needs to be reset. The only way to turn the system on is to unplug from power for 5 minutes and then plug back in, wait for light to stop blinking and then turn on. I have cleaned the filter on the left side. The model is Mitsubishi WD-62725. any ideas?
Nov 26, 2007 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
298 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
