Question about Garden
Weedeater blower model BV 200 won't start after replacement of spark plug.
  • 63 Answers
Make sure you're getting gas, spray gas into air intake and see if it runs. if it does, and stalls aftewards, keep spraying until old gas is used up, also, if this does not work, check to see if you have spark
Posted on Jun 28, 2010
Weedeater gbi 22 leaf blower will not start, how do I start it and what could be the cause?
Replace the spark plug, drain last years fuel and use fresh fuel mix.
Sounds like you may have a fouled plug. A speck of carbon or other debris can short the gap causing ZERO runtime.
Apr 02, 2015 | Weedeater Garden
The fb 25 weedeater has fired off a time or 2 one time it started but died like 2 seconds and only fired one more time with25 pulles
Put a little in the cylinder via the spark plug hole and see it will run a second or two. If it does then your carburetor needs repairs or replacing.
Most shops will not even accept these cheap unit in for repairs.
Mar 14, 2015 | Weedeater Garden
What is the carb ajt for my weedeater bv 2000
A carb jet size change would not be likely as a fix. You may need to clean the carb and the jet(s) though
Oct 04, 2014 | Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
My weedeater has no spark at all
If there is no spark then I would suggest checking out the plug wire for cracks or breaks If there is none present then the ignition coil could be finished Take it off take it into your small engines dealer and get him to test it.
Dec 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
What is the spark plug gap for weedeater bv 1850
You shouldn't need to set the gap on plugs when you buy them for handheld equipment. It should be close enough straight from the factory. You can find replacement spark plugs at PartsBuggy.com.
Oct 12, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Will not fire after replacing spak plug
if it will not spark after the plug change, then you need to go deeper to the coil, and the magneto, alot of times the magneto plate just needs to be sanded or wire brushed.
Nov 13, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I have a ryobi weedeater model 764r. how do i reset the mixture screws.it won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
319 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
