Question about Dewalt compact Jig Saw kit DW317K
Blade don't stay tight
Blade comes out often
Fan making a really loud knocking noise
sounds like the blade is loose and hitting the housing. check that the set screw is tight. also check to see if shaft is worn where the blade wont stay tight.
May 27, 2014 | Ovens
Blade won't stay tight
if the blade keeps coming loose replace the hub that holds the blade in place
Jun 26, 2012 | Toro Garden
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
How to tighten blade
if the blade is unbalanced it will not stay tight and should be replaced then with a block of wood to hold the blade from turning tighten the replacement blade
Jun 10, 2012 | Black & Decker 19" Electric Lawnhog...
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Have a husquvarna RB 150 and the belt that drives the cutter blades has come looose, how do i tighten
Normally there is no adjustment for a belt that drives the cutter assembly, the problem is the belt has stretched out and is no longer tight enough to engage the blade sufficintly, in which case it needs to be replaced. Hope This Helps Don
Nov 07, 2009 | Husqvarna Garden
Windshield motor make noise but the wiper don't move
Remove the wiper blades then remove the cover and you will find that the linkage has come off the motor.Replace the linkage or fit a new one.Hope that was helpfull.
Aug 07, 2009 | 1996 Acura TL Series
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Dewalt compact Jig Saw kit DW317K Logo
59 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
