Question about Kodak EASYSHARE 5100 All-In-One Printer
Rollers won't pick up photo paper.
I'm using KodakPremium paper and the rollers don't pick up the paper. Photo (shiny)side is down, w printing facing up. I keep getting check your tray. Printer works fine on paper8.10 reg for printing documents etc. but wont do 4x6 photos.Easy share 5100 is the model.It is about 3 yrs old. (You would have to check my reg. for sure.)
I know it isn't a software problem since it does print, just not when I slide in the 4x6 paper. Carol Pehrson
    Problem Solver:
  • 17 Answers
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
Posted on May 31, 2010
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Tip
PRINTER IS OUT OF PAPER
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cause
Any of the following issues can cause this issue:
  • The paper trays are empty or overloaded.
  • The paper is fold over.
  • The shiny side of the paper is not loaded in the tray face down. Photo paper; load the rough side of the paper facing up.
  • The paper is too smooth for the product.
  • The paper might not be occupied with the feed rollers.
  • The paper width guide is pressed against the paper stack too firmly.
  • The paper tray is not entirely inserted into the printer.
  • The paper setting in the print driver does not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are dirty.
Check the media and print settings
a) While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
b) If the printer is not already on, turn it on by pushing the power button. Swap any paper that is ripped, dusty, wrinkled, or bent. If the paper is coiled flatten the paper by gently bending it in the opposite direction of the curl or swap the paper.
c) Verify that all the paper is the same size and type.
d) Tap the stack of paper on a flat surface to align the edges
e) Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
f) Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
g) Change the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper in the trays.
  • Open a document by an application in which it was created.
  • Press File
  • Press Print
  • Press properties. The Printer Properties dialog box will come up.
  • Press the Paper Quality tab.
  • In the drop-down menu, select the size of the paper loaded in the paper tray.
  • In the Type drop-down menu; select the type of paper loaded in the paper tray. Press ok.
  • On the Print dialog box, press ok to print the document.
  • Try print again.
If the issue is not solved, try next steps
  • Switch off the product and unplug the power cable.
  • Open the access door to access to the rollers.
  • Clean the rubber rollers with a fur-free cloth lightly moistened with water.
  • Make sure that any papers that rest on the input tray, which are located at the back of the roller are cleaned. Mop with clean cotton moisten with water, might be required to reach these rollers.
  • Close the access door and plug in the power cable.
  • Try print once again.
on Sep 19, 2010 | Office Equipment & Supplies
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
I've had this printer for a few years and it'd give me problems when I want to print from the photo tray 75% of the time. Very frustrating. I don't have money to put into a new printer either.
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent. NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause Any of the following issues can cause the error message to appear:
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Dec 11, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ever time I try to print anything, I get a message saying the printer is out of paper. But it's not out of paper! There is plenty of paper in the tray, which I keep reloading, only to get the same...
Cause
The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
The paper is too slick for the product.
The rubber paper-feed rollers are dusty.
a)While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
b)If the printer is not already on, turn it on by pushing the power button.Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
c)Verify that all the paper is the same size and type.
d)Tap the stack of paper on a flat surface to align the edges
e)Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
f)Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
g)Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1.Open a document in the application in which it was created.
2.Click File
3.Click Print
4.Click Properties . The Printer Properties dialog box displays.
5.Click the Paper/Quality tab.
6.In the Size is drop-down menu, select the size of the paper loaded in the unit.
7.In the Type is drop-down menu, select the type of paper loaded in the unit.
8.click ok.
9.On the Print dialog box, click OK to print the document.
10.Try printing again.
1.Turn off the product and unplug the power cord.
2.Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door.
3.Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
4.Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5.Close the access door and plug in the power cord.
6.Try printing again.
Sep 16, 2010 | HP Officejet 6000 All-In-One InkJet...
HP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
Oct 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    Pictures will not print and paper will not load for printing pict
    You need to push the paper through just touching the boundary of the printer paper tray
    Feb 12, 2009 | HP Photosmart D7260 Printer
    My HP Photosmart D7260 is not printing pictures
    Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
    Please note:
    • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
    • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
    Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
    1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
    2. Lift the Out-tray and place a stack of paper in the In-tray.
      • Load the paper with the side to be printed facing down.
      • Load paper in the portrait orientation with the shortest edge feeding into the printer.
      • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
      • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
    3. Push the paper into the printer as far as it will go without bending.
    4. Lower the Out-tray.
    5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
    6. Close the main cover.
    Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
    Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
    HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
    1. Lift the top cover of the printer and remove the photo cassette from the sheath.
    2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
    3. Lift the main cover.
    4. Slide the paper width guide all the way to the left.
    5. Lift the Out tray and remove any paper that is in the In tray.
    6. Line the photo cassette up with the far right edge of the In tray.
    7. Gently slide the photo cassette into the printer until it snaps into place.
    8. Lower the Out tray.
    9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
    If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
    If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
    Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
    EPSON R1800
    Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
    Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
    Kodak EASYSHARE 5100 All-In-One Printer Logo
    198 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
