Polaroid 2611 - TLXB 26" HD Widescreen LCD TelevisionStuck in standby mode
TV has worked well until now. When unhooking Laptop from VGA port, got message "no VGA signal, will power down". I didn't pay it much attention as I presumed once laptop was disconnected, I would restart TV and change input. Since then, however, I have not been able to get TV out of standby mode (red light is on, will not turn to blue).
  • 3 more comments
  • Etwine2 Apr 08, 2008
    Sure did; but no joy. I just know that it's gotta be something simple and obvious... other ideas
  • Etwine2 Apr 09, 2008
    pazman:
    I repeated the recommended process 3 times. Still no joy. VGA pins are not touching. I have tried turning on TV both with remote and control buttons on the side. I know the remote is good as it works with the second TV of same type.
    I do appreciate your ideas and coaching...
    Pazman:
    Thanks. The service call is what I am down to at this time. Again, thanks for the help.
    etwine2
  • dolly2lee Sep 04, 2008
    I have hooked my computer up to the tv and I cannot get anything on the tv. It says no signal. I have checked cords & unplugged tv & turned back on but still nothing
  • Eric5150 Oct 19, 2008
    same exact thing here
  • 81 Answers
Have you done a hard reboot??
Posted on Apr 08, 2008
  • Anonymous Apr 09, 2008
    this is what I would do, I would disconnect everything reboot the tv then one by one start to connect each component and see what happens, if nothing still then get a flash light and see if any of the pins from the vga input are touch at all. that could cause a issue.
    let me know
    [email protected]
    sorry to here that, maybe a service call for the power board module
SOURCE:
I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Sep 29, 2012 | Polaroid 2611-TLXB TV
Trying to hock tv and computer wirh hdmi cable. Keeping getting no signal. What am I doing wrong?
Does your TV set has more then one HDMI input?
Enable the laptop/pc port Use the TV remote to select the correct HDMI input.
Jul 28, 2011 | Polaroid 2611-TLXB TV
I have a Polaroid 26"
Sounds like your fiddling may have shorted out the main board of the TV.
Not to say that this wouldn't have happened eventually, there's a good possibility it was defective from the start.
If you have warranty, try to go through that, you should be covered. Otherwise, for a 26 inch, most likely not worth repairing, good luck!
Mar 16, 2011 | Polaroid 2611-TLXB TV
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
VGA shut down
call Polariod
replace 'box'
(their description, not mine)
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Stand by light is on but won't turn on
something in the tv is blown try unplugging it for 30 min then try again
May 08, 2008 | Polaroid 2611-TLXB TV
Televison & Video Logo
359 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
