Question about Dell E193FPC 19" TFT LCD Flat Panel Monitor
Monitor won't stay on more then a second or two
I can get it on, the icons come up and it shuts down right away, the power button lights up, turns sort of orange and stays that way sort of as if it is in stand by mood
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Posted on May 31, 2010
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
How do I turn off yellow on my hp monitor? yellow light on monitor stays onm after computer uis shut down.
Push the power button. The yellow light it to indicate that the monitor is idle or that it has no signal, and will stay on as long as the power is on to the monitor.
Jan 30, 2011 | Computers & Internet
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
I have an Acer H243H widescreen monitor; it has speakers built in. My problem is that the Volume controls constantly show up on the screen and I am unable to get it to go away and stay gone. The touch...
When this occurs with mine, I power down the PC through windows and the monitor using the lower right power button, let bot sit for 10 - 20 seconds, then power on the PC and switch on the monitor a second or two later and the icon disappears.
Before I did this I found it would eventually disappear.
Acer support claim the H243H is a touchscreen unit, that's what the icon is all about, buy you must have Vista to use it, not XP.
Jul 15, 2009 | Acer Computers & Internet
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
My screen is black
hit FUNCTION and usually F5 button. Look for the keyboard key with the "monitor" icon. If not hold power button down and power the laptop down. Wait 10 seconds and reboot.
May 25, 2009 | HP Compaq nx6110 Notebook
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Dell E193FPC 19" TFT LCD Flat Panel Monitor Logo
198 people viewed this question
Alun Cox
