Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I have a poulan 2450 chainsaw and i can't get the primer bulb to **** any gas, the bulb is in good condition however there is gas leaking out of the gas cap in the center of it, do I need a new gas cap and could this be why I can't get suction from the primer bulb?
    Brigadier General:
  • 4,088 Answers
You may be overfilling the tank somewhat so that expanding fuel (from engine heat) is being pushed out of the vent. Check the fuel filter for plugging and all of the fuel lines for any rot, splitting, or other damage. The primer bulb is supposed to pull fuel from the fuel filter, then through the carburetor and on to the primer which should push the excess back into the tank through another line. If the above does not allow the primer to pump fuel, then dismantle the carburetor, clean with carburetor spray cleaner, and rekit it. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--theory and troubleshooting. This information applies to most brands of carburetor. Hope this gets you running!
Posted on May 31, 2010
How to change/ Replace Poulan 2150 chainsaw primer bulb
I have attached a video on chainsaw primer bulb replacement from YouTube. There are many great videos about chainsaws on YouTube.
I hope this helps.
http://www.youtube.com/watch?v=sNj2oO9L9ic
Jul 01, 2014 | Poulan 2150 Chainsaws
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi Sirs, I have a Poulan Woodshark model 1950. The gas lines deteriorated and I bought new ones, together with the primer bulb and the chain. Now I can't remember how to connect the lines. I need help....
The fuel line from the tank with the filter on the end goes to the carb inlet, closest to the metering cover usually a chrome cover held with four screws, the other conection on the carb goes to the suction side of the primer bulb, normally the shorter of the two conections, the pressure side of the primer goes back to the tank, this pipe just sits in the tank to act as a return, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Jul 23, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Leaks gas probloms strating
check your fuel line to the primer or the primer bulb. if it is leaking you will not prime properly and won't run properly due to sucking air instead of fuel.
Feb 21, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
No gas to carb
There should not be a vent hose--it probably goes to a port on the primer bulb. Check the fuel filter for plugging and the condition of all fuel lines (they should be original rubber, not plastic replacements). Try priming the carburetor with the bulb pump--it should pull fuel into the bulb after several pushes. If nothing, check the condition of the primer bulb--it should be soft without cracks or holes.The primer is supposed to pull fuel from the tank's fuel filter, into the carburetor top section, pass into the lower section through the metering valve which is controlled by the diaphragm, then out to the input port of the primer and out the other primer port to return fuel to the tank. Go to: http://www.drystacked.com for an excellent 12 page article on theory and troubleshooting of Walbro carburetors. Hope this helps!
May 16, 2010 | Poulan Reconditioned Chain Saw 33cc 14in...
Vapor lock
The tank vent is a bronze plug inserted into the tank casting--the caps are not intended to vent. Check the fuel filter for plugging and the condition of the fuel lines and primer bulb. You should be able to fill the bulb with fuel after several pushes of the primer bulb. Have the fuel lines been changed? Hope this helps!
Apr 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan chainsaw primer bulb replacement
You can find replacement parts on amazon, here Amazon com poulan chainsaw chain parts. I hope this was helpful. Cheers
Mar 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Model 2175 poulan - pump up primer bulb and it colapses. When i put fuel in head it runs till gone..
Change out the primer bulb and the small gas lines going to carb and primer. One of these has a small crack to let air get by and this is how you get a flat primer bulb. Pick the kit up at lowes for $6-8.
Feb 03, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
501 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
