Question about Yes YDV-325 Flash Media Camcorder
Sony Camcorder DCR-TRV11E
Camcorder does not function. LCD self-diagnosis reads C32:10. Can't remove the cassette to insert again; have also disconnected mains lead and re-connected, but no response. Help!
Doug.
Jg,
Posted on Dec 29, 2008
  • h3roesandkin Dec 29, 2008
    DCR-TRV11E
    Hi My camera works in 'Player' mode as do all other functions, yet when I try to record the viewer and the 'window' stay blue for a moment and then go black.. I can still see the info such as battery level and tape time etc. The camera still accepts instructions ie record but I cannot see anything..? There are no error codes showing..
    Many thanks in advance
    Genius:
  • 3,422 Answers
HI,
Taking off the battery and reattaching it is a simply way to reset the camera - if the error comes back, then you have to repair it basically. The C32:10 gives the technician an indication that the problem is a mechanical issue, which explains why the camera won't open properly. If you can see some mechanical thing wrong that you can fix, go for it. Otherwise, http://www.videoonerepair.com will give you a free estimate if you send them the camera.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 08, 2008
    Master:
  • 555 Answers
A manual for your camcorder can be found here.
  • Matt Jurach
    Matt Jurach Apr 08, 2008
    C32:10 refers to a problem with the tape reel mechanism.
    Many other frustrated users have actually found that lightly tapping the camcorder on the door side will clear this error.
    Also try this fix:
    1. Remove tape.
    2. Manually forward the tape for about five revolutions of the
      reels.
    3. Reinsert the tape.
    These techniques just move the tape reel system around until the error sensors stop complaining.
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
Jun 11, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
On a sony digital handycam digital 8 TRV 250. what does the self diagnosis display c:31:32 mean?
A malfunction other than the above that you can service has occurred.
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder
Oct 21, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
I'm trying to clean the heads on my TRV 950, I purchased a cleaning cassette and this error code appreas on the lcd c:31:22
Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Aug 12, 2009 | Sony Handycam DCR-TRV950 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
C:31:23
Hi Tariq,
Please see the detail below for the said error codes C31:23.
Apr 11, 2009 | Sony Handycam DCR-TRV240E Digital...
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Sony dcr-tvr285e
Dear Davjhakra,
Your camcorder has mechanism problem and skilled person can handle it. Unskilled person might damage the it. You sould go to nearest Sony service shop for proper handling of DCR-TRV285E
May 26, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Yes YDV-325 Flash Media Camcorder Logo
256 people viewed this question
Top Yes Video Cameras Experts
Are you a Yes Video Camera Expert? Answer questions, earn points and help others
