Question about Goodman CKL60AR60 Air Conditioner
NO POWER TO MY LOW VOLTAGE THEMOSTAT
We had a power surge and there is no power to my thermostat. I have power to the air handeler and the compressor outside. I have oppened the trane air handeler in the attic and am looking for this circuit borad and three amp fuse I have seen on the help boards but i can not find either, I have found a 25 amp fuse inside the handeler but I believe this is to the blower moter, due to the high amp rating. Can you tell me where this fuse is, Its driving me crazy tring to find it. thank you for your assistance ib advance. (The trane air handler number is TWEO36P 130BO)
    Genius:
  • Goodman Master
  • 1,363 Answers
Rarely is the blower motor fused that might be a 2.5 amp fuse read across the fuse if you have 24 volts it is bad.
Posted on Aug 12, 2015
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 306 Answers
SOURCE: the air handler won't shut off
As long as the t-stat fan switch is in the auto position the problem sounds like fan relay is stuck. It looks like a little black box about 2 inches square. Has 5 positions on it two of them are for 24 volts.
Be sure you turn off power before pulling it out. Make note of the arrangement of the wires maybe label as you remove them. ken
Posted on Dec 27, 2008
  • 26 Answers
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
t1m130
  • 86 Answers
SOURCE: Hello, I have a Trane blower motor that want
are you getting 120v at the "cool" terminal on the board try taking one of the motor leads and hooking it up to the 110v going into the control board if that works check to see if you have 24v at the "G" terminal if you have 24v at "G" and no voltage coming off of "Heat Or COOL" then i would replace the board
Posted on Jul 14, 2009
co7196
  • 3433 Answers
SOURCE: Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Posted on Jul 29, 2009
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
Tip
Understanding Air Conditioner Electrical problems is not as hard as you can make...
Air Conditioners are broken down into two electrical systems, though they work together1. Low voltage control unit 24-28 volt control unit like thermostat and other switches and relays( also feeds compressor contactor,reversing valve, and defrost board on heat pumps)on the outdoor condensing unit .When there is no power to the thermostat,it cannot turn on the indoor fan or any other load (indoor or outdoor). In this case, first confirm there is power available (closed breaker,closed disconnect) If you have power the fan on manual switch on the thermostat should be able to turn on the indoor fan.If it doesn't, then your control voltage is most likely lost. check the transformer and 3 amp fuse in the air handler .2.The high voltage components are your compressor and your fans, both indoors and outdoors.High voltage 240 volt loads are controlled by the 24-28 volt control voltage.3. Remember, a thermostat is just a big on/off switch.4.Be careful and always play it safe when working around energized circuits5. Leave it to the pros, especially if you're inexperienced or nervous about electricity
on Aug 22, 2013 | Heating & Cooling
Compressor won't come on I want to by pass thermostat
First check power or (high voltage) to outside unit if good make sure you have thermostat voltage or (low voltage) to the outside unit.
Feb 09, 2014 | Fujitsu 24C1 Air Conditioner
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
I have power to the main, air handler breaker, and tothe compressor disconnect, but nothing is coming on.
Sounds like you have a low voltage problem,you need to check for 24 volts at the transformer/thermostat,low voltage wiring ect....if all checks out then could possibly be a contactor problem.
Jan 06, 2010 | Ruud Heating & Cooling
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
No power to thermostat
in the usa 110v or in aus 240v.
Jun 07, 2009 | Heating & Cooling
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating /Air unit
Remember that the fan is generally not controlled by the thermostat...unless you have one of the power saver units. The compressor which does the cooling is. If you turn the thermostat to a warmer setting, there should be a click and the compressor should shut off. If not, the control is bad.
Jun 13, 2008 | Honeywell Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
191 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
