Question about Craftsman 675 Torque 190 cc 21" Push Lawn Mower (CA) ()
I can't pull the starter rope more than a few inches. Just purchased the mower. Its a craftsman push mower
  • 44 Answers
Your recoil spring may be broken, take the top cover off and see if you can pull the rope with it off.
Posted on Jun 06, 2010
  • 468 Answers
Try taking the spark plug out and pulling it. If you have a bunch of gas, oil, or water come out, and the engine turns over, you will have your problem. If you have stuff in there, you will want to pull the starter rope a bunch of times to try to push it all out, and then dry off the spark plug, put it back in, and give it a go. You may have to leave the plug out for while to let the cylinder dry out.
Posted on May 31, 2010
Starter rope won't pull on my Craftsman rotary mower model 917.4787A.
the cable may be stuck or you may have to take the top off and rewind the rope.
Nov 05, 2016 | Garden
Recoil rope on my briggs and stratton lawnmower will only pull out a few inches
One of many causes, have you tipped the mower on its side recently? is there oil in the engine( has engine seized? has the rope got wrapped around starter cup?
Apr 01, 2015 | Garden
Craftsman 917-377150, the pull cord broke and the housing to replace it is rivited in place, can I drill these out, but then what?
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Jul 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
How do I change the recoil starter?
This is how to replace the rope, to replace the assembly, simply remove the three screws and install a new one.
Gary
Jun 14, 2011 | Craftsman Garden
How do i change the starter cord? i 've removed broken one and have new one on order. Any other cords i've changed simply had a knot in one end, but this one is really different. thanks!
Gary
May 03, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I start twice (when I pull starter rope) then the rope won't go back can I know what happen
Your starter/recoil unit has malfunctioned. Disassembly/inspection down to the point where you can get the recoil off will be required. Remove the engine cover screws. The recoil unit may be part of the cover or may be under it. You will easily be able to access it. Replacement parts for your mower are readily available.
Apr 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Replaced pull cord on craftsman push mower but wont retract back like its's been pulled all the way out it's all slack. What do i need to do to get it to spring back? It's 5.5hp self propelled mower about...
if you get this the first time get a lottery ticket fast.
take the recoil off and apart, check to see if the spring end is broken off. (sometimes you can bend a new hook into it but it will usually break because its hardened).
buy the way, Usually you can wind a rope around what the recoil connects to, to start the engine at this point.
take the handle off the end of the rope and wind it around the drum/spool leaving a few inches hanging out.
hook both ends of the spring to their stops and wind the spring tighter about four turns, then thread the end of the rope through the hole and pull on the rope and test the recoil. Don't lt it go.
pull the rope out and put a "marline hitch" in it or use a visegrip pliers to hold the rope out and tie the handle back on.
replace recoil.
if the rope looks fuzzy most all hardware stores have it.
good luck
Apr 29, 2011 | Garden
Craftman push mower wont pull rope out
You would have to remove the engine cover, then unbolt the few screws that hold the starter/recoil unit above the flywheel. Then remove it and see exactly what the problem is. This is a fairly easy process and things are much clearer with the plastic covers out of the way.
Aug 16, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman 675 Torque 190 cc 21" Push Lawn Mower (CA) () Logo
365 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
