Question about Admiral AAV7000A
Admiral Model #AAV7000A Washer
Washer started making a loud squealing noise and started to smoke from underneath. It smelled like burnt rubber. The tub was full of water at the time. The washer would not cycle. It would not drain or spin. We looked underneath. The belt looked OK. There is a part we think is a pulley? It is made out of plastic. The plastic looks burnt and melted. The pump motor also has what looks like a pulley attached to it. That pulley will not turn freely either. Would you recommend that we replace the belt, the pulley or the pump motor? Also, where can we get a schematic for this washer? Thank You!
  • RDO3 Jul 26, 2008
    Washer started making a loud squealing noise and started to smoke from underneath. It smelled like burnt rubber. The tub was full of water at the time. The washer would not cycle. It would not drain or spin. We looked underneath. The belt looked OK. There is a part we think is a pulley? Also, where can we get a schematic for this washer? Thank You!
  • jstowell Jul 31, 2008
    When it goes into the spin cycle, it makes a weird humming noise and smells. It will not spin or go into any other mode. It is full of water right now.
I hear two different problems between the solutions here. If you see damage to the pulley, replace the pulley. In most cases I've cut the pulley out and broke it into pieces. Putting the new one on is a much easier task. In the case of the machine still holding water... inspect the belt under the machine and the pulley. If they look good, replace the pump. You are sure it isn't a timer problem?
Just in case, with the machine in spin, push down on the selection ring behind the PUSH/PULL on/off while the machine is turned on. Does it start to spin and pump? if so.... the timer is probably the answer.
Posted on Sep 16, 2008
    Genius:
  • 1,073 Answers
Replace the pump
Posted on Apr 10, 2008
SOURCE:
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
04 aviator there was a loud squealing noise smelling burnt rubber ,belt broke. Belt good conditions. Replaced belt and started. loud squealing noise, same burnt rubber. What's causing this to happen
with car off and keys in pocket open hood and check all pulleys and components something not turning possible seized such as idler pulley alternator noise is belt being dragged over something not turning
Aug 06, 2015 | Cars & Trucks
When i turn the wheel my car makes a loud noise and smokes, it smells like burnt rubber, is it safe to drive it
Sounds like the power steering pump is locking up and the belt is slipping. Get it checked out before you drive it.
Feb 05, 2014 | Dodge Cars & Trucks
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
My washer is making a grinding noise during spin cycle and it smells like burnt rubbert
The grinding you hear is from the drain pump. I have replaced around 60 this year alone. There is a insert that works its way down around the pulley on the pump and restricts the pump. The burning rubber is from the belt trying to turn the pump but cannot. Here is a link to the part you need. You can gain access to the pump by removing the four screws on the rear bottom left side of the washer. You will need to remove the belt before you remove the pump.
Aug 11, 2011 | Maytag Admiral AAV7000A
One of the pulleys underneath has waht looks like melted black plastic on it, it started making awful noise then we smelled rubber burning, then it wouldnt go at all. tipped it over and sa belt intact, but...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 25, 2010 | Admiral AAV7000A
Washer will not drain
clean pump and drain hose
Aug 26, 2009 | Admiral AW22 Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Admiral AAV7000A Logo
242 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
